IWATA Eclipse HP-CS or Harder & Steenbeck Evolution CR plus Two in One
  • JR
    • May 2015
    • 18273
    #16
    Originally posted by stillp
    Another H & S user here! I'm opposite to Bob (Bowcat) though, I use the 0.2mm nozzle all the time. With the 0.4 I put too much paint on.
    If found the same Pete, full trigger and it's every where, now resort to the feather light touch and still keep the .4.
    • AlanG
      • 6296
      #17
      That's where this little aftermarket life saver comes in. An official Iwata flow control gizmo. Basically fit it. Screw it in/out until you reach the desired maximum flow and there you go. No more guess work every time you pull back on the trigger. Fantastic for doing Luftwaffe mottling
      • JR
        • May 2015
        • 18273
        #18
        [ATTACH=CONFIG]n1112426[/ATTACH]
        Ah that's good, very similar to the Evolution H& S where you can set the amount of trigger movement. The thing is I love the Ultra but It doesn't have that lock .
        • stillp
          • 8093
          • Pete
          • Rugby
          #19
          Yes, it has that, but I'm just not careful enough when it needs the delicate touch.
