Which Airbrush For a Beginner
    I have a small fan heater running in my shed, I can only just hear my (almost identical) compressor start up over the sound of it. Both are underneath my bench.
    When I took it to work I couldn't hear my compressor running at all over the general workshop background noise, I had to put my hand on it to feel if it was going.
    So - pretty quiet!
    • BattleshipBob
      • 6791
      • Bob
      • Cardiff
      #17
      I bought a Iwata sprint jet, only problem no tank so always on, got as a package with the Iwata eclispe. Been very good and easy to use
      • Bortig the Viking
        • Mar 2019
        • 780
        #18
        Mine is as noisy as my wifes hair dryer, but only when its keeping the air pressure up otherwise its silent great when you stop airbrushing in between coats etc.
        • Steven000
          • Aug 2018
          • 2825
          • Steven
          • Belgium
          #19
          Originally posted by Supabuild
          Can anybody compare the compressor noise to anything they can think of so I can get an idea please.Thanks guys.
          Search on youtube for a review of this compressor, then you can hear it running :thumb2:
          • Supabuild
            • Jan 2020
            • 29
            #20
            Thanks guys,like the youtrube idea. Have a good idea now what my wife is in for!!
            • Peter Gillson
              • 2594
              #21
              A couple of years ago /i y one of these on ebay for my daughter when she was into painting her nails. it was around £15
              I was surprised by the quality, not as good as my Badger but for £15 I think its a good starter twin action airbrush.
              Peter
                AS-186 a very reliable compressor.
                Unless you are prepared to pay 3 times the amount all compressors are around 50 decibels.
                If you go for a Bambi which has a deep freeze type compressor very quiet it will cost about £300
                Also about 4 times the size of the ABS. My ABS is now 7 years old.
                There are a lot more expensive. If you look closely they all have very identical parts to the ABS just
                re-badged & cost more. You get the same air from an ABS to the more expensive.
                The ABS comes fitted with a moisture trap & pressure gauge..
                They are all noisy (except a Bambi). I created an MDF box with vents at the rear. & a door on the front.
                Lined this with acoustic foam (Ebay) & cut the noise to just a very light rumble. About £25
                The Neo by the way is not an Iwata manufactured Airbrush it is Chinese made & bought in by Iwata.
                  Hello John,
                  Welcome to the forum, I agree with your choice of airbrush and with care should last until you have saved up and gained experience to go further. The 186 is well reccomended and should suit you. Noise from these moden compressors is well down the scale, gone are the days of wearing ear defenders and watching it dance across the floor.
                  Please ask away if you have more questions and there should be an answer come back to you.
                  Mike.
                  • Supabuild
                    • Jan 2020
                    • 29
                    #24
                    Hi guys,sorry for the delay in answering. I've been scouting around for the AS 186 compressor on AMAZON but have become rather confused with all the 186 out there. I need to get it from Amazon as I have a gift voucher for there.Could somebody be kind enough to provide me with the correct link to this compressor.It would help me a lot. Thanks again .
                    • Jim F
                      • Feb 2015
                      • 317
                      #25
                      Hi Johm,
                      Trry this
                      regards Jim
                        • 15653
                        Hi John
                        That deal Jim found looks good. If you don't need the airbrushes then THIS would suit you.
                          I think that Switzer one is the same kit I bought. When you take it apart it has Royalmax cast inside it, as I guess most of them do, since they all just seem to get re-branded.
                            Reading all this I’m surprised at the noise feedback from the recommended compressor.
                            I’m using an old Micon compressor that I inherited and it’s LOUD, I naturally assumed all compressors were loud.
                            It’s always surprising where useful info pops up on these forums.
                              Also, regards feedback on badgers.
                              I do have a badger 200 series I’ve had for 20 years. It’s a siphon feed single action with the needle adjustable manually via a rear mounted thread.
                              It works reliably, not the easiest to clean though. You can remove the needle and the nozzles but that’s it. Everything else is one piece.
                              They also use a 1/4” hose connector, which I find odd.
                                All the piston jobs are noisy around 60 plus decibels.
                                Get a Bambi which uses a refrigerator compressor & all you hear is as your fridge compressor.
                                Run a group to ensure that a building project does not exceed noise levels set. For that I have
                                a decibel counter which has been calibrated as accurate.
                                Just checked my AS compressor. With the compressor in my noise insulated cupd door closed
                                the decibel rating is 48 decibels.
                                With the door open on the cupd (still insulated sides & rear) the decibel rating is over 60 decibels.
                                The readings taken as if sitting with the compressor under the work top. 60 is loud. Our TV which
                                we have at a good level as we are old is about 50 decibels.
