Using other brush needles
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Evening
    Seen a few comments about having a smaller needle for a airbrush
    Looks like a quite expensive option with not just the needle being replaced. I assume you have 2 brushes and is it worthwhile??
    Both mine have a . 35 standard needle
  • AlanG
    • 6296
    Bob. I have just the one brush. It came with the standard 0.4mm needle. So i bought a 0.2mm conversion kit from John. I can change between them within 5 mins
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      Will have a look in his shop.
      Thanks Al, much snow yet!@
      Cannot see a Iwata kit, bugger
      • AlanG
        • 6296
        I bought mine from John years ago. Shoot John a PM and see if he can get you one.
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          Will do Al. How does the nozzle fit in a H an S? The Iwata is a push fit, but on the one i have just repaired pliers had to be used so can see it being damaged after a few swops
          Thinking of changing my one brush to 0.2mm and leave the other at 0.35mm??
          • AlanG
            • 6296
            If i had two brushes then i would defo have one at 0.4mm and the other at 0.2mm. Or i'd buy the H&S lol
            • BattleshipBob
              • 6792
              • Bob
              • Cardiff
              Sounds like a plan Al, just emailed the very helpful tech at the airbrush company
                Easily, lol
                When I the swap needle & nozzle on mine it takes longer to get them out of their case in the drawer than change the parts. Once the parts are laid out it's maybe 30 seconds taking it steady, 10-15 if you are in a rush. Everything just unscrews with fingers, no tools needed.
                • BattleshipBob
                  • 6792
                  • Bob
                  • Cardiff
                  Iwata is a push fit nozzle, so afraid of causing damage after time. The nozzle in the damaged one had to be removed with pliers so do not think its designed for regular removing?
                    Not sure about that Bob as I haven't got an Iwata brush. Would seem strange for them though, for it to be hard to remove I mean, since it's something you'd probably do regularly for thorough cleaning. Is there any crud built up where it fits causing it to be sticky?
                    With a H&S the nozzle slips inside the air cap and the assembly screws on in one piece.
                      • 15696
                      Hi Bob
                      My Iwata has a screw fit nozzle. It comes with a special little spanner. It is quite a delicate set up so care is needed to prevent damage or a crossed thread. The H&S nozzle is held in by the screw in nozzle cap which screws/unscrews with your fingers.
                      Hope you get things sorted.
                      • BattleshipBob
                        • 6792
                        • Bob
                        • Cardiff
                        Thanks All
                        The very good tech says iwata do not do a 0.2 only 0.5. Had a look at the parts list and yes its true
                        Cannot see the sense in buying another brush to get a 0.2, as i have 2 Iwatas
                        • AlanG
                          • 6296
                          Thanks All
                          Do you know something Bob you are totally correct. I always thought my brush set up was a 0.4mm/0.2mm. But checking the reference numbers on the item boxes i have they are indeed 0.5mm/0.3mm.
                          Learn something new every day.
                          • BattleshipBob
                            • 6792
                            • Bob
                            • Cardiff
                            The tech said he cannot see much use for 0.2, only for inks etc and they can block easirly
                            • AlanG
                              • 6296
                              Well the 0.3mm set up i use is perfect for Luftwaffe mottling. Just thinking of investing in a digital pressure gauge so i can accurately set up my spraying airflow
