Well that was interesting.
I found the airbrushes both a Clarke bottom feeder and a Fengda gravity fed both easy to set up and use. I think I prefer the gravity fed but that was mainly down to a bad paint mix on the Clarke. Both worked fine after cleaning and starting again. The actual painting was also easier than I thought and I had to question if I was doing it right. I didn't even practice, just loaded paint and sprayed against a paper towel while I played with the needle and paint balance. I think thats the good thing is that whilst experience will come it is a fairly straight forward job which is credit to the airbrush design. Resprayed the underside of my Hurricane and it worked well. I think I still need to get comfortable with mixing the paint. I found IPA doesnt seem to mix well with Vallejo Air as it tended to clump a bit. But with water and a couple of drops of flow improver I had much more control and consistency and no clogging. Stripping down and cleaning the airbrushes was a doddle and quite simple really.
So far so good and I feel more confident than I did before and was over analysing the potential issues. Next comes experience of course and that, obviously, takes time.
