Problem with AB'S
    • 18890
    Hasn’t just blown a fuse has it?
      Not sitting on the hose are you???
        Morning Tim
        Checked the hose from the compressor to ab ok
        Took compressor head off. [ATTACH=CONFIG]n1114244[/ATTACH]
        [ATTACH=CONFIG]n1114245[/ATTACH]
        [ATTACH=CONFIG]n1114247[/ATTACH]
        [ATTACH=CONFIG]n1114246[/ATTACH]
        No dirt , that plate In photo above I turned over.
        Now reassembled andg this time no pressure at all .
        When trying to undo the head bolts again one has refused to move, the socket head part is so soft .
        Result going to cut my time and just look for a new one .
        Can't undo the screw, even with grips or
        Pliers.
        Thanks for all the ideas and help every one .
        John .
        John,
        Have you checked the preassure valve itself, there could be some gunk in there. If it is the valve give me a shout on the blower.
        Mike
        • JR
          • May 2015
          • 18273
          #19
          No Tim, power is there.:thumb2: just no pumping .
          Originally posted by MikeC
          John,
          Mike
          I cleaned out the bottom release valve, just a little damp in the trap, and no I wasn't sitting on it, but when I trip over the lead it nearly ended up in the garden !:angry:
          John.
            Have I got the wrong end of the stick John? Seem like you are saying you turned the black plate over?
            If you refitted it upside down then that's probably why there's no pressure at as the diaphragm valves will now be working the wrong way.
            • JR
              • May 2015
              • 18273
              #21
              Don;t think so Andy, I used the photos to put the thing back as it came off, of course I could well be wrong, mechanical things and I don't mix :upside: The cap screw is the problem now as the internal faces are so soft they have given up , a bit like me !
              I've ordered a new Iwata , not going to mess around. Will keep the old one and let my mate have a look whens he's fit and well .
              Thanks .
              John.
                John.
                Sorry.....:smiling2:
