Mayday Mayday - Sudden Airbrushing Problems :(
  • Komedy
    • Jan 2020
    • 307
    Hi all
    This has come out of nowhere, today I picked up the airbrush to to a couple of test pieces and no matter what paint mix or brand the airbrushes are spittling / spluttering when I open the paint feed, it gets worse as I increase the paint feed. For a few seconds its OK then gradually deteriorates. Getting this on Vallejo, Ammo and Primer. Have used all these before with no problems. Have tried both my Iwata and H&S same issue across both. If I run Cleaner through them its fine I get a nice controllable mist spray, anything else splutters. Spraying at my normal pressures for the above paints. I'm not getting any clogging either?
    Kinda stuck right now, only thing I can determine is that the compressor is a little hot so I am letting it cool and check the tank drain and a little water came out not excessive though.
    Any feed back very welcome
    Warren
  • AlanG
    • 6296
    Do you have a water trap on your air line?
    • Komedy
      • Jan 2020
      • 307
      Hi Alan yes.
      Its seems with thinner, cleaner and water its perfect anything else and both brushes are having problems
        First thought if they are spraying cleaner through fine is that you have a slight blockage. Unusual for both to be affected at the same time though.
        Cleaner is much less viscous than any paint so can get through a minor blockage that other materials can't.
        • Komedy
          • Jan 2020
          • 307
          Have stripped and cleaned both, they are spotless. Letting the compressor cool now for a bit.
          • stillp
            • 8085
            • Pete
            • Rugby
            Have you drained the compressor tank?
            • Komedy
              • Jan 2020
              • 307
              Hi Pete
              yes undid the little drain spud on the bottom of the tank and got a little fluid out of it, not a huge amount had to shake it a little to get more out.
              Warren
              • stillp
                • 8085
                • Pete
                • Rugby
                Is the air hose kinked?
                • Komedy
                  • Jan 2020
                  • 307
                  Nope changed hoses to be sure.
                  Whats most odd everything is ok for the first few secs, but as I increase the paint flow it starts to wrong, immediately thought I was getting clogging, but no all clear
                  Stumped right now
                  • stillp
                    • 8085
                    • Pete
                    • Rugby
                    Has to be something limiting the air flow, but I can't think what.
                    • Steve Jones
                      • 6615
                      Have you unscrewed and cleaned out the front nozzle and the hole where airbrush needle comes out of the front of airbrush??
                      • AlanG
                        • 6296
                        Having re-read your initial post i was wondering if you are getting a constant pressure? Seems like your air flow is fluctuating
                        • Komedy
                          • Jan 2020
                          • 307
                          It's what I'm hoping is the case so have cleaned up for the night and will see how we are in the morning.
                          Thanks all for the responses so far
                          Warren
                          • Bortig the Viking
                            • Mar 2019
                            • 780
                            If it's both brushes, surely it's got to be hose or compressor, maybe it needs a service or is failing for some reason.
                            • JR
                              • May 2015
                              • 18273
                              As you say you've the same problem with the Iwata and H&S,the same issue across both Warren .
                              Has to be the compressor then, what type is it ?
