Mayday Mayday - Sudden Airbrushing Problems :(
here are a couple of examples of what I'm getting as a result of this "spittling". These where done straight after the video above with my H&S with Ammo green. Running at 20 PSI again and no matter what I do I cant get smooth even coat down, if I open the feed further the "spittling" effect gets worse.
I'm at a real loss and starting to loose heart a little. This morning I swapped out the 0.2mm Nozzle and Needle combo in the H&S for an unused 0.4mm set never out of the box and attempted some tests on previously primed spoons. I was using Ammo Mig with one drop of thinner to ten paint.
Spoon on the Left - First Test to try and get a dust coat down at 18 PSI and lightly pulling back on the feed
Spoon in Middle - Second Test with reduced PSI lightly pulling back on the feed
Spoon on Right - un-primed attempt to build up several layers - grainy finish
Going to try other paints now with the 0.4mm setup.
I really appreciate everyones comments and suggestions to date
WarrenComment
Yes their thinner and previously I was able to spray these out of the bottle no issues just would have built up in fine layers. The main problem I see at the minute is the speckling effect I am ending up with as a result of this "spittling" noise I get as gradually open the paint feedComment
Sorry this thread is becoming image heavy but only way I can explain what I am getting
ok here are some shots from priming more spoons - MIG one shot primer although building in layers from left to right. You can see immediately on the left two spoons the speckling. 1st two done at 22PSI second two reduced to 18PSI
Warren.
I can sympathise with you. It nearly made me give up ,the shear frustration with trying everything in the book.
When you showed the two videos was I right in seeing a gap in the spray at one point and then it cleared and started again.
Think you should try to find someone local who can try our your ab's.
If they work then it's the compressor on the hose .Comment
Ah. I don't think we have any other posters from NI.
Is there a branch of Games Workshop near you? Maybe they have a compressor you could try your airbrushes with.
Just a thought - I know you tried a new hose, but do you have a quick release adaptor on your hose, and did you change that?
PeteComment
Ok last set of Pics
Vallejo on top of the Primer at 15 PSI with Flow Enhancer
Next up Tamiya 50/50 with Tamiya Thinners at 20PSI
Now interestingly before doing the white above I did one Red Tamiya 50/50 same as the white but here u can see I have the expected result and nothing changed when I did the white above but the speckling is back.
So all the pics are in the one post here are the other two from this morning.
Ammo Mig with 1 Drop Thinner to ten paint at 18PSI
and then prepping more spoons - Ammo one shot primer 22PSI attempting layer build up.
Getting fed up painting bloody spoons :tired:Comment
