H & S Infinity strip down
  • stillp
    • 8083
    • Pete
    • Rugby
    Having bought a seal kit for my Infinity a while ago, I thought I'd strip it down and pop it in the ultrasonic cleaner, then change all the seals. However, I can't get the Teflon seal under the paint cup out. Can anyone suggest how to remove it?
  • KarlW
    • Jul 2020
    • 1522
    Be sure to use a rubber mat inside the cleaner, they're not really recomended for airbrushes as they effectively shot blast precision parts but H&S say if you must, use a mat.
    If you're replacing that seal anyway just use a pick.
    • stillp
      • 8083
      • Pete
      • Rugby
      Thanks Karl, the parts are in a plastic basket suspended in the cleaner so should be safe. I struggled to get a pick into the seal, it's quite hard, so wondered if there's a trick to it.
      • KarlW
        • Jul 2020
        • 1522
        I find cutting tricky o'rings helpful to remove them, but does it really need to come out? I never had mine out.
        (Obviously you need to have a replacement to hand.)
        • stillp
          • 8083
          • Pete
          • Rugby
          Well, it does now it's been stabbed with a pick! There looks to be some hardened paint under it.
          • stillp
            • 8083
            • Pete
            • Rugby
            It's out. Dug it out with a scalpel blade.
            Hard to believe the amount of paint that's the wrong side of the needle seals.
