Hi,
I have the above airbrush with a 0.4mm needle and nozzle fitted,it’s a new airbrush. I normally use an Apex airbrush, but today thought I would use the H and S evolution. I was using Vallejo model air sand yellow paint on some Warrior wheels. In the past,I’ve never thinned Vallejo model air,so added some paint into the paint cup,and started spraying,but the nozzle kept blocking and stopping the paint spraying. I cleaned the airbrush, and tried again,but still the same problem, but intermittently spraying paint. Could this be because the paint needs thinning? I did try airbrushing some Stynylrez grey primer, and also had problems with that,and it normally doesn’t need thinning. Probably stick with the Apex,as I’ve never had any problems! Sorry for the long post.
Martin
Martin
