When cleaning after a session I always remove the needle. To make sure there is nothing on the tip also to ensure the needle is free of junk where it passes through the seal in the barrel.
Deep clean I remove the nozzle & soak in Pro Cleaner which is the best i have found to date. Leave this soaking over night. Also remove the spring part & trigger this gives access to the plunger under the trigger & give this shot of airbrush. Plus a spot on the needle part the way down to give lubrication at the seal.
Have H & S 7 Iwata. Iwata, in my opinion, is a far better engineered brush . Has fewer seals than the H & S & relies on metal to metal. But the devil to deep clean. Reming the nozzle to soak is not easy as is the H & S.
H & S dead easy brush to take apart. For this reason I uses the H & S for priming & varnish as they are easy to clean.
Iwata produce an HP-BS smaller than the average. I also has the advantage as have a number of Iwata brushes of having the cup recessed well into the barrel giving a better view. Down side you cannot change cups if you like to do a session without refilling. For me I like the better sight line.
