Battery powered airbrush
JIm,
looks interesting, useful for those small jobs that you can't be bothered to fire up your mains compressor.
They seem to say 1-2 hours use in normal conditions............... What I have found, with cheap rechargeable tools is that the batteries have a limited number of recharges, and performance falls off pretty quickly, also they don't hold their charge very well, you can charge them fully, then, even though you haven't used it, it'll go flat.
Still, might be worth a punt!
Dave -
I would think the battery will make the brush heavier to use though. This will make it more a spray gun than a brush and subtle work will be more difficult.Comment
dont see the benefit..................what would it save?.....not time cos you still got to clean it.............modellers tend to paint in front of an extractor so mobility isnt an issue for us........could see a little benefit if you were doing detail work on say, a custom car or bikePer Ardua
We'll ride the spiral to the end and may just go where no ones beenComment
Bit of a nuisance when the battery starts to run down during a session.
Just wonder about reliability of pressure. My toothbrush when charged near removes your teeth but soon reduces in speed.
Pressure must change in this case whereas a compressor electric mains is constant.
LaurieComment
Thanks for the link Steve. Interesting thoughts from you all. The conclusion of the video flagged up by Steve is what you'd expect. The cheap one was a waste of money and the more expensive Spray Gunner one from USA at least works well.
JimComment
i suppose they might be of value if say, you are just starting out and dont want to go to the expense of buying a compressor.......or perhaps for someone who dosnt want the noise of a compressor runningPer Ardua
Must say that was well filmed and the close up shot were good.
Agree with Dave about the battery life on the cheap ones, at work if you stupidly bought a cheaper replacement battery for a tool it wasn't long before it was useless.
Was he spraying ink, as there was no tip drying, the other thing is of course seals, can't imagine them being the best of lasting very long in some cleaning fluids.Comment
I'm definitely interested in this, I never realised they could be portable.
The US one in Steve's video seems the best bet for me, but can't find one in the UK. Anyone have any suggestions/links - say £60 or less (the US one from the US is £20 p&p - meh)?Comment
Hi Bobby,
I think that this is the same as the american one, for 61£: Link to Amazon . I just pulled the trigger and bought one - should be with me in about 11 days. This is going to be my first paintbrush and I hope it will be good enough for a complete beginner.Comment
Hi Bobby,
