Hi All. I am a recent returnee to scale modelling. Given the size of my fingers 1/24 is the smallest I can go! I am retired but the average 14 year old would tell me a lot about modelling, the thing being is that I have totally re-fallen in love with it even though I am still pretty crap at it. So here (finally) is my problem. I have an Iwata Neo AB. I am using Vallejo Surface Primer, 74.601 Grey. I wash the model in a light detergent mix and then rub the surface down to remove any shine. I spray the primer on, let it go off for at least 24hrs and then carefully check it to make sure it is all smooth. Recently when I then spray the paint on (Vallejo) and sometimes even if I try and paint on, it comes out looking like oil on water !(best description I can come up with). My 'set up' is in the shed (very large) unless there is snow when I moved a lot of it indoors (wife not happy!). So, can anyone tell me what I am doing wrong? Is temperature anything to do with it? Or am I just an idiot, which would not surprise me!! Over to you experts
Airbrush Paint Finish
Sounds like surface contamination. Are you rinsing off the detergent Chris? If not, it’s probably worth it. After that I wouldn’t rub down again because you may be making the surface dirty again and it is migrating through the primer back to the surface. Just let the primer air dry then spray your top coat. -
Sounds to me like you're doing everything right!
Caveat - I am NOT an expert.
When you say 'oil on water', do you mean the paint is pooling, as if it's separating? And I understand that this is happening when you are applying the paint on top of primer, is that right? Are you thinning the paint at all?Comment
Hi Chris as with some of the others on here I've never washed a kit plastic or resin let alone rubbed the shine off ,saying that I know a lot of the chaps do so unless you've left a soapy residue I cant see a problem there , plus as you've described the primer seems fine .Sounds stupid but have you mixed the paint throughly prior to thinning and have you mixed paint and thinners properly. Its not as if your in the shed working with temps hovering around zero the only thing I will ask how well do you store the paints is there a chance they've got frosted?Comment
Hi Chris
Welcome to the forum.
Do you man the paint beads up on the primer or do you mean that somehow the paint looks like the rainbow effect seen in puddles when oil floats on the water?
If the paint is beading up then the primer surface is not compatable or the paint is over thinned with water. If you are thinning with water you are diluting the "structure" of the paint - try using Vallejo thinner. As the guys have said light coats and work at a lower pressure. The surface tension which causes liquids to bead up can be reduced with a drop of wetting agent in the paint. A TINY drop of washing up liquid can work.
Just my random thoughts :rolling:
Don't give up - you'll sort it.
JimComment
Hi Chris
JimComment
Ok. I suspect then that the pressure might be too high and you're putting too much paint down too quickly.
Consider lowering the pressure to below 20psi so you are delivering the paint in a more controlled way and try experimenting with the thinning ratio. I use 15psi and thin 50/50, but you'll need to figure out what's best for you.
Also try to lay a thin coat first and build it up. Don't try to get all the paint on in one pass.Comment
Which Vallejo paint are you using? Model air or model colour? Vallejo do an airbrush thinner as well as a straight thinner.....I assume the airbrush thinner has more flow aid in it to help with airbrush work.Comment
I haven't really looked at the paint other than the colour matches that I want. I will have a look.Comment
