The soldering on my olympus gave up, so it's time to replace it.
The options are bewildering and I'm just dipping a toe in to research, but there's no substitute for earned praise from those that know, so I'm reaching out to you guys for some help if that's ok.
I'm looking for something to do general coverage to fine detail spraying, so max 0.3mm nozzle. It will not be required for heavy duty spraying, such as varnish.
It should be gravity fed and dual action.
It will be spraying exclusively acrylic paints.
Would any of you aircraft modellers recommend anything?
