Strange problem with compressor
  • JR
    • May 2015
    • 18273
    #16
    Had a problem with mine , it ran , just no pressure ! After a lot of messing about binned it .
    Bought one of those with out a tank from Iawata .
    • stillp
      • 8087
      • Pete
      • Rugby
      #17
      I hope I won't need a new one John. It works fine above 15psi. If the new regulator doesn't cure the problem I might try an inline regulator.
        • 18890
        I must admit that’s how I run my Iwatta. Set at full delivery pressure and stepped down at the airbrush stand by a second PRV. It means I can keep the compressor under the bench and just have to switch it on and off at the start and end of a session. All the fiddling to set pressure can then happen straight from my chair when I’m working….
          • 15653
          Interesting. I'm the same as Tim. The compressor is under the bench and set at 25 psi. I have a MAC valve on the airbrush which I use to reduce the pressure to what I need.
          • stillp
            • 8087
            • Pete
            • Rugby
            #20
            I might think about a MAC valve Jim. I hardly ever change my pressure setting though.
