Hey guys,
I am so excited to be part of the community :smiling3:. This is my first post (apart from the introduction), and I will jump right to the point.
I have been researching the last few days on how to best apply the Vallejo black Primer on a F-14A 1:48, and I must admit I am kind of confused. I have concluded that most modelers had great success with 0.5mm needle/nozzle and spraying out of the bottle at 20psi, with 1 or 2 layers of primer.
Then I watched the Vallejo video on YT (video) on how to spray the primer, and what they suggest (of course they also want to push some more products to the market), is to follow the below recipe:
1. 0.4mm nozzle/needle @ 25psi (I guess 0.5mm would do too)
2. Use 50% primer and 50% Vallejo thinner (15 drops primer, 15 drops thinner)
3. Use Vallejo improver at 33% of the primer proportion (5 drops)
4. Spray multiple layers as a first base
5. Work on and sand off any imperfections
6. Switch to a 0.3mm nozzle/needle @ 18psi for the final fine layer
7. Use 70% primer, 30% thinner (no flow improver this time)
This looks a bit overkill to me, however it is the actual product vendor suggesting this approach.
Now, I am just undecided which path to follow
. Any help is most welcome.
thx,
//G
thx,
//G
