You can get them for Iwatta (and probably other manufacturer) as well Pete…
Basically it’s a needle valve (hence the fine control) air flow reducer. I would disagree with the (quite garbled) H and S description though. Simply put, it’s not a pressure reducer by any means. It is a way of modifying air flow by changing the size of the hole through which the air passes.
Air delivery to the airbrush is a function of pressure and delivery tube cross sectional area (CSA). Pressure is the driving force, in effect, how hard the air is pushed through the delivery tube. CSA dictates how much air is allowed through at a set pressure.
Most of us (me included) change airflow by modifying the air pressure being delivered by the compressor, usually by means of an in line pressure reducing valve (PRV).
This device, on the other hand, modifies air flow by playing with the other part of the flow equation. It changes the CSA of the delivery tube. Increasing or decreasing the CSA by using the valve therefore changes airflow.
Having this device fitted to the brush itself is extremely convenient, especially if your compressor is fitted under your bench. If you need to change airflow during a paint session you can do it at the brush itself. It also increases flexibility of operation because it’s one more thing you can play about with.
Saying all that, it’s probably time I bought one
