New to Airbrushing question?
  • David Lovell
    • 2186
    #61
    Bear in mind there is nothing what so ever wrong with the airbrushes included in the set up ,they will give perfectly acceptable results in fact correct thinning of paint and air pressure there is no difference ,yes more expensive airbrushes are nicer to handle and use but were spraying plastic kits here not spraying ferrari cars, I've got both expensive and as there known cheapo generic Chinese ones ,the cheap ones are used as often if not more than my expensive ones .
    Once again at the risk of becoming boring it doesn't matter who's airbrush you use its down to correct paint thinning and air pressure else they won't do what it says on the box.
    • JR
      • May 2015
      • 18273
      #62
      Exactly , thinning and air pressure. Rather like using a hawk David, its a skill learnt.
        • 15646
        That compressor, John, is a quality piece of kit. It gives a constant air flow as it has safeguards built in. If my memory serves me it costs around £300. Cheap compressors with no tank, around the £60/£70 mark will not be so protected against fluctuating air flow.
        • JR
          • May 2015
          • 18273
          #64
          Probably wasted on me then Jim , I was so hacked off when the AS186 packed up I thought no more tanks !and bought it.
            • 15646
            Definitely not John. The way your current French cafe dio is developing puts you up there with the best.
            Also with savings interest rates at about 2.5% at their very best and inflation getting close to 10% you might as well spend and enjoy it!!!
            • David Lovell
              • 2186
              #66
              Not that's its of any interest to Modler Bob but I have a tankless compressor , bought it after my AS186 packed up. Posted this because some say you get a pulse with out a tank ! Iv'e never had that occur.
              [ATTACH=CONFIG]n1180006[/ATTACH]
              John i havent a clue what this pulsing air pressure phobia is how far back in the past do some of them live ,twenty odd years ago I had a second hand tamiya compressor and airbrush this was the diaphragm type you could almost hear it wheezing but it didn't puls bad enough to even imagine it was affecting the paint job ,as you know I dont belive in all the myths and secrecy that have become associated with airbrushing i always try to use the manufacturers thinner along side their paint as it was developed to be used with it there for it should give the best results. OK if others want to use witches milk or dragon spit ,window cleaner whatever that's fine crack on but someone starting doesn't need to hear it ,just grab a airbrush paint and recommended thinner and enjoy learning the pit falls no one gets right straight out of the box.
              • JR
                • May 2015
                • 18273
                #67
                Thank you Jim , yes at the rate is going Mrs R is going to have a new I pad
                • Modler bob
                  • May 2022
                  • 277
                  #68
                  Originally posted by stillp
                  Bear in mind that those airbrushes are the generic cheapo Chinese ones, and you'll probably want a better one (H & S, Iwata, Badger, Bartsharp, etc) fairly soon.
                  If my memory serves me well peter.
                  Didn't people say similar things about the Japanese goods/market?
                  and just look at their cameras et al
                  Just saying loike:smiling3:
                  • stillp
                    • 8086
                    • Pete
                    • Rugby
                    #69
                    Yes David, but how long have you been airbrushing? I find my H & S is a lot more tolerant of incorrect thinning and air pressure than the cheapo that I started with. It's also a lot easier to clean.
                    Nothing wrong with Chinese manufacturing per se Bob, but a lot of stuff shipped from there is rubbish. The Chinese government is making some efforts to stamp out counterfeiting and copying, and to encourage more high-quality manufacturing, but they have a long way to go.
                    • David Lovell
                      • 2186
                      #70
                      As we say anybody can plaster the trick is using a trowel to get it from the hawk to the wall ,but as with a airbrush if it ain't mixed right sand and cement or plaster its bloody hard going. Dave
                        • 18883
                        My first “proper” airbrush set up was an Aztec airbrush driven by an AS186. The compressor simply couldn’t keep up with the Aztec. It was so air hungry that the pressure tank used to empty over about fifteen seconds so I had to stop and let the air tank refill before continuing. I was therefore never airbrushing at a constant pressure. That affected the paint job alright :tongue-out3: . Think of it as really slow cycle pulsing and you’ll be pretty close to the effect I got. Still did some decent paint jobs with it though……..I got used to the sound it made and just stopped spraying while it refilled the tank.
                        Once I changed to a better airbrush it improved because the compressor could keep up. I then changed to an Iwatta compressor (gave the AS186 to models for heroes, along with two airbrushes like those in the eBay add) and improved it yet again. As an aside, I tried the Aztec with the Iwatta compressor, and that couldn’t keep up either……I know many people have got great results with an Aztec, Jakko uses one, for example, but there must be something wrong with mine :tongue-out3:
                        Completely agree ref proper paint thinning with the correct thinners. That is by far the most important skill you need to learn. As I’ve said several times, as a starter set, these are fine. If/when you get your skills to the point where these airbrushes or compressor don’t do what you want, then that’s the time to upgrade.
                        In fact, if you are just starting out in the hobby an airbrush is not a necessity. Magazine modellers will tell you they are, but they really aren’t. I’ve been doing this for around forty years now, but only really started using an airbrush regularly about twenty years ago. Most of my railway modelling was done with flat brushes, not an airbrush. Ron spanner doesn’t use one at all and his results are excellent, for an example on this forum.
                        • Bugatti Fan
                          • Mar 2018
                          • 314
                          #72
                          Those Aztec airbrushes have not always had a good press. Some love them and others wish they had never bought one!
                          With any airbrush there will be a bit of a learning curve to overcome.
                          • David Lovell
                            • 2186
                            #73
                            Ooh twenty odd years longer if you go back to the little badger siphon airbrush I had the one that used aerosol cans stood in bowls of warm water even bought a adapter to use with a inflated lorry tyre inner tube before leaving the hobby for girls and beer. Still ive sussed mixing paint and setting the air pressure so my cheap brushes work just dandy. If you had read what I had said earlier you would have noticed that I said my expensive airbrushes are nicer to handle i don't know why a expensive brush should be easier to clean a airbrush is a airbrush they all basically have the same parts ,mind I only clean mine by flushing through with mr hobby tool cleaner and maybe a squirt of thinners just to finish off ,oh and if I can be bothered I occasionally pull the needle out the back way and wipe of any residues works for me.
                              • 18883
                              The issue is the amount of air it needs to work properly. When it does work it is a very good tool. Easy to clean, easy to swap nozzle and paint cup sizes, and the ability to change from double to single action on the fly. Nozzle quality was a bit hit or miss, but they were cheap enough to bin and replace.
                              I should have gone the same way as my brother in law. He’s a model engineer with a very well equipped workshop. He just uses his heavy duty shop compressor. Switch it on, let it fill with air, then airbrush for hours without the compressor needing to switch on again and refill the tank……nearest thing to silent airbrushing there is :thumb2:
                                • 18883
                                I had one of those badger jobs…..worked surprisingly well. Only ever used it for primer though…..it was a bit like having a refillable spray can.
