Home made spray booth
  • treebeard51
    • Nov 2022
    • 4
    I am about to get back into small scale models. Regarding airbrushing requiring a spray booth I contemplated using my existing cooker extractor & creating a removable cardboard enclosure beneath, sat on the cooker. Do you think this would be ok ?
    Almost certainly. Spray booths sold for airbrushing don’t have that powerful a fan in them, I would expect one intended for a kitchen to be much stronger.
    • treebeard51
      • Nov 2022
      • 4
      Thanks ! I will give it a go !
      • KarlW
        • Jul 2020
        • 1522
        Really depends on others in the house........I can just see "The Look." now........
        • treebeard51
          • Nov 2022
          • 4
          Yes< I thought about Madame's reaction ! I Thought if made of a cardboard box type construction, funnelling into the overhead extractor, I could simply lift it easily away. What do you think ?
          • Neil Merryweather
            • Dec 2018
            • 5180
            • London
            I would worry about the overspray-it always gets somewhere you don't expect.....
              • 18881
              Sounds good to me Stephen. You could probably use tumble dryer extraction hose to duct away the fumes if you wanted to as well..
              • adt70hk
                • Sep 2019
                • 10400
                I've not done it but I've seen it done....
                As Jakko says the 'suck' will be far stronger than a specialist booth. Even at ours lowest suck my cooker hob hood is far louder and stronger than my spray booth.
                • treebeard51
                  • Nov 2022
                  • 4
                  Having looked at commercial ones it probably is not worth the effort. Any recommendations as to which one ?
                    • 18881
                    I’ve used one like this for many years.
                    You can fold it down when not in use.
                    Also depends what paint you are going to spray and where you are going to spray it…..you will probably need a P3 filter spray mask as well.
                    • Steven000
                      • Aug 2018
                      • 2822
                      • Steven
                      • Belgium
                      Mine is made from mdf and an old kitchen hood, I use it always on the max speed setting so it's a bit loud but works great. I blow it outside with a plastic hose.
                      Cheers, Steven
                        I did that with the spray booth I bought a few years ago. It came with an aluminium-foil hose that tore on every attempt to get it over the exhaust tube, so I went to a store and bought a plastic one for tumble dryers instead.
                        • PaulTRose
                          • Jun 2013
                          • 6442
                          • Tattooine
                          I always used to use a big plastic storage box when I used to make my iwn
                          Per Ardua
                          • simontie
                            • Jan 2010
                            • 1506
                            I have a 1000 wide hood 3 speed and i also used an in line extractor half way down the exhaust hose just for over kill, the light unit fitted to most hoods is quite dim so i stripped this out and wired in anLED fitting much better light, for the sides i used 2 bits of perspex the rear wall is 12mm ply and on the front i screwed on some clear plastic curtains like the ones found in warehouse doorways so you can reduce or increase the working area and when you close all 3 curtains its powerful enught to pull them in a bit
                            the bottom of the unit i wall papered well not quit but i lined it with wall paper unused rolls masked in to place these keep the area reasonably clear of over spray, just replace once the over spray mounts up couple of pictures of it.
                            bought mine on gumtree for next to nothing and it works really well only issue i have had was the exhaust tube there was some escaping of dust so i duct taped it up Click image for larger version
ID:	1188581Click image for larger version
ID:	1188582Click image for larger version
ID:	1188583Click image for larger version
                            simon
                            Why is common sense not so common?
                              • 18881
                              bought mine on gumtree for next to nothing and it works really well only issue i have had was the exhaust tube there was some escaping of dust so i duct taped it up [ATTACH=CONFIG]n1188581[/ATTACH][ATTACH=CONFIG]n1188582[/ATTACH][ATTACH=CONFIG]n1188583[/ATTACH][ATTACH=CONFIG]n1188584[/ATTACH]
                              simon
                              Excellent, wish I had the space for that to be honest. Much better than the small one I have……
