Portable spray booths
  • Mickc1440
    • 4775
    Dear all, the continuing cold spell and winter in general is really hampering my progress on modelling projects as I spray out in the garage. After several discussions with swmbo I’ve sort of convinced her that a spray booth indoors is a viable proposition. Can anyone help with recommendations please as I’ve seen some I definitely wouldn’t waste my money on. All help great fully received
    • 18881
    Depends on your budge I suppose Mick. I’ve used one of these for years, and have no complaints.
    Not the best construction, but it controls overspray. The biggest thing it can handle is two engined aircraft at 1/48. It won’t eliminate lacquer thinners smell though. If that is what you want you would need to invest significantly more money than that, and probably sacrifice the portable aspect.
    • AlanG
      • 6296
      [ATTACH=CONFIG]n1190250[/ATTACH]
      What make and model is this Tim?
      • Mini Me
        • Jun 2018
        • 10711
        Check www.micromark.com
        • KarlW
          • Jul 2020
          • 1522
          [ATTACH]469529[/ATTACH]
          I use an activated carbon filter on the exhaust hose, does a pretty good job of dealing with the solvent smells.
            • 18881
            It’s this one Alan
            Lots of options out there though, so look around and get the best price.
              • 18881
              Nice idea Karl. Usually the hose is dangled out of the window…..but at this time of year that’s a great improvement.
              • KarlW
                • Jul 2020
                • 1522
                I don't have a window and don't really want to cut a hole in the shed wall, so this was my best option. Plus a carbon filtered mask and I don't smell my paints at all.
                Only issue is the pest place to get them is hydroponics stores so people think I'm growing herb.........
                Got the idea from seeing soldering station fume extractors in factories.
                  • 15638
                  I have a booth like Tim suggests. I do vent it out of a window. It has given many years service. It's a bit flimsy but does the job. I do wear a mask for lacquers, belt and braces.
                  • Mark1
                    • Apr 2021
                    • 4156
                    Mine is basically what Tim has but with led lighting, bought mine from bartsharp. They do a slightly larger one and probably worth the few extra quid to be honest.
                      • 18881
                      Mine pre dates LED lighting LOL…..
                      • adt70hk
                        • Sep 2019
                        • 10400
                        Hi Mick
                        I have one just like Tim's. I do vent it out the window and wear a mask to be on the safe side.
                        Also if you have to a good lamp(s) you can shine it though the cover to his effect. I've done it this way for years..... Below is it with my brand new lamp.
                        Good luck in the hunt.
                        ATB.
                        Post in thread 'What's on the bench 2022' https://www.scale-models.co.uk/threa...59/post-647304
                        • Mickc1440
                          • 4775
                          Thanks very much gents, plenty of food for thought
                          • Scratchbuilder
                            • Jul 2022
                            • 2689
                            Mick,
                            I showed mine on 'Latest Aquisitions' At the moment it is in the shed waiting for the weather to improve so that I can construct a better spray box for it.... Money not well spent.
                            • PaulinKendal
                              • Jul 2021
                              • 1608
                              • Kendal
                              Good idea. How long does the filter last?
