fengda airbrush question?
  • Modler bob
    • May 2022
    • 277
    Hi guys/gals
    Thinking it's about time I got into spraying etc.
    I can't afford the top-of-the-range kits, so I noticed this on Amazon..........
    I'd very much appreciate your thoughts on it please?[
    regards
    Bob
  • peterairfix
    • Jul 2012
    • 11069
    Should be OK for a first timer myself I would have gone for one with a tank on it.
    • adt70hk
      • Sep 2019
      • 10400
      Yep. Tank is a good idea
      • simontie
        • Jan 2010
        • 1506
        Same one iv been using for years changed the water trap last year as i cracked it but produces a good steady pressure. Used the airbrush for a while to itwas ok for learning (i still am) but since changed it for an evolution one once i could afford it
        Simon
        Why is common sense not so common?
        • simontie
          • Jan 2010
          • 1506
          Simon
          Should say it runs all the time when spraying but it quite, quiet
          • Modler bob
            • May 2022
            • 277
            Excuse my ignorance. But what difference does a tank on the top make?
            • stillp
              • 8085
              • Pete
              • Rugby
              Saves the compressor from running constantly, and delivers a more constant pressure. Perhaps also delivers cooler air to the airbrush. Whether any of that makes any practical difference I don't know!
              • outrunner
                • Apr 2019
                • 2420
                I have used a tankless compressor for a few years now and notice no difference between it and the one with a tank that a mate lent me to start with. Obviously the motor runs all the time when painting but it is not noisy, you pays your money etc.
                Andy.
                  This is the later version of the air compressor I've been using for many years - a fair few fellow forum members have one, or very similar..............
                    • 18881
                    As a starter kit I’m sure this will be fine…it will certainly allow you to learn the craft without too much outlay. Later you will know exactly what you want from your kit and can upgrade accordingly.
                    The idea of the tank is to smooth out the air delivery, eliminating pulses. However, my Iwatta compressor is tankless and runs on demand. It’s air delivery is completely pulseless.
                    • Mark1
                      • Apr 2021
                      • 4156
                      Ive been using a tankless one with no issues but mine has auto start/stop when i pull/let off the AB trigger
                      • Modler bob
                        • May 2022
                        • 277
                        Cheers Dave.
                        That's more my price range :smiling:
                          Cheers Dave.
                          I bought mine for around the same price, but it came with two el cheapo airbrushes - ideal for learning to use the airbrush. I still use one of the Chinese airbrushes for priming & basecoats.
                          John has some reasonably priced quality airbrushes in the SMS https://www.scalemodelshop.co.uk/0-3...ms-200-p17352/ - don't forget as a SMF supporter you get a 5% discount in the shop. After you've become comfortable using the basic airbrush, then, you can look for more expensive & higher quality bits of kit.............
                          • langy71
                            • 1947
                            • Chris
                            • Nottingham
                            That's the same one I've been using for the past few years Dave, and I've got no complaints with it...and I still use the cheapo brushes for laying down basecoats / varnishes... :thumb2:
                            • stillp
                              • 8085
                              • Pete
                              • Rugby
                              I use an AS-186S from John in the shop. That came with two cheapo airbrushes, but I couldn't get on with them and bought a Harder & Steenbeck. No problems with the compressor though.
