Dr. Strangebrush, who is a chemist, did some testing with various cleaners. Personally I use alcohol, followed up with a quick squirt of Tamiya Extra Thin Cement/Airbrush Cleaner if I’ve been spraying acrylics. I find if I just use alcohol it tends to dry out the airbrush.
By the way, if you’re going to use a mix with Windex and it has ammonia don’t let it sit on your brush. Flush it out with something else afterwards - the ammonia will attack the nickel plating If it’s given time to work.
Cleaner test
Cleaner test
