What paints & thinners do you recommend for the Fendga
All paints will work, it's not down to the compressor, it's depending on what size needle and nozzle your airbrush has as to how much you thin them, but that can also vary from by paint brand.
Ammo Modelling Guide ?How To Paint With The Airbrush A.MIG-6131 AMIG6131 Ammo Scale Model Shop UK, 5* Customer Service, Fast Delivery, Reward points on every order
I'm a Dork (but you all already knew that :smiling2: )
I found the hose and paints on the floor, they must've fallen from the box when I opened it. Doh!!!
Done similar. Got an order of little blokes once, a box in another box surrounded with polystyrene kibbles. Took the box out for recycling, and heard something moving around. I thought I’d better check the polystyrene kibbles before discarding it…..found a few figures and thought ”that’s nice, freebies”…..turned out I’d actually ordered them and nearly thrown them away…..
Been there done that...more than once I might add, there's nothing like the feeling of embarrassment you get whilst your digging around in the bin knowing your neighbour is stood in their kitchen watching you...
Hard to go wrong with most of the AS-186 style compressors that you find on Amazon. It’s the crappy airbrushes included in many kits that would make you want to pull your hair out.
That's good to know thanks.
I will test it once I have made a booth, and tested the brushes.
just a thought...
can I change the needles on this brush OK?
As some of you know I purchased my first Compressor kit (Fengda Airbrush kit compressor set FD-186K with airbrush BD-130 )
Just wondering if the theBD-=130 airbrush can be improved upon by simply changing the needles?
Bob
[HEADING=2][/HEADING]
