Red Hot Compressor
  • Jad
    • Jan 2023
    • 47
    Red Hot Compressor
    As a bit of a newbie into the world of airbrushing, is it normal for the compressor to get red hot and completely cut out?
    Had been spraying for quite a while when I lost compression and felt the compressor and was red hot.
    It’s FD-186. ?
  • KarlW
    • Jul 2020
    • 1522
    It’s FD-186. ?
    No, there should be a pressure switch that'll stop it doing that.
    I had one (Pressure switch) fail and that caused the compressor to over run and get hot.
      • 15638
      It is not normal. I would suggest something is wrong. The compressor will get warm after a while but it shouldn't get so hot it cuts out with normal use.
      • Jad
        • Jan 2023
        • 47
        I got a refund from Amazon.
        Any recommends for another compressor? Or do I go again with the same one ?
        Ps. The compressor I e is 2 months old and they’ve told me to bin it !
        • Waspie
          • Mar 2023
          • 3488
          • Doug
          • Fraggle Rock
          I would guess it's down to budget and your personal requirements for what you want it to do!!!! Best you can afford is usually my criteria!!!
          • Jad
            • Jan 2023
            • 47
            Gone back to the compressor. It runs now it cold again. But don’t trust it now.
            • Jad
              • Jan 2023
              • 47
              Limited budget. £100.
              Is anything any good for that ?
              • Mini Me
                • Jun 2018
                • 10711
                Is it a Piston driven or Diaphram type compressor?.....If piston type, you might look it over to see if there is a lubrication port for servicing it with compressor oil. Something to consider before chucking it in the bin. I know that most of the piston types come factory serviced prior to leaving the facility for marketing. Worth a look see though.
                • Gary MacKenzie
                  SMF Supporter
                  • 1057
                  • Gary
                  • Forres , Moray , Scotland
                  AS-186S Airbrush Compressor with Cooling Fan AS-186S AS186S Scale Model Shop Scale Model Shop UK, 5* Customer Service, Fast Delivery, Reward points on every order
                  • Jad
                    • Jan 2023
                    • 47
                    • Jad
                      • Jan 2023
                      • 47
                      this is the one. 2 months old
                      • Jad
                        • Jan 2023
                        • 47
                        So this is basically what I’ve got ?
                        • Gary MacKenzie
                          SMF Supporter
                          • 1057
                          • Gary
                          Bought mine ( as-189 ) on Amazon ( john's shop on amazon ) and it has been reliable from day one , presurises , stops , and when you start using the pressure it rebuilds it, never noticed it get very hot , though I tend to do 15 minutes at time max , and not spraying constantly.
                          • Jad
                            • Jan 2023
                            • 47
                            [ATTACH=CONFIG]n1199262[/ATTACH]
                            I was spraying for 2 hrs ?
                            • Mini Me
                              • Jun 2018
                              • 10711
                              From outward appearances I would guess it is a Diaphram type.....meaning it is a dry system. If it is running constantly and not building pressure to the cut off point I can understand why it would over heat. Two things you can check is your pressure cut off switch and the actual diapharam that is in the motor, if it has a defect or tear in it it will not build sufficient pressure to activate the pressure switch causing constant running that could lead to overheating.
