H&S Ultra 2024
  • Bri62
    • Jan 2023
    • 1877
    • Brian
    • Widnes Cheshire
    H&S Ultra 2024
    Anyone know if there is a .05 nozzle kit available for this struggling with the standard nozzle on anything lower than prime will spray fine for a while then clogs that's using Vallejo Air
  • Waspie
    • Mar 2023
    • 3488
    • Doug
    • Fraggle Rock
    Haven’t had an issue with mine Brian.
    Works well and I’ve used all the settings now.
    I always thin initially to 50 - 50 with the ultra the refine that with my drip test!!
    • Mark1
      • Apr 2021
      • 4156
      Vallejo can have a tendency to dry round the tip of the ab, a regular wipe with a cotton bud and thinners should improve things.
      • Andy T
        • Apr 2021
        • 3238
        I think the standard size in those is 0.45, so practically what you are asking for anyway.
        I doubt that is the problem though, more likely you aren't cleaning the tip regularly enough, as Mark suggests.
        • Waspie
          • Mar 2023
          • 3488
          • Doug
          • Fraggle Rock
          After watching the H&S videos on the Ultra I use a short bristled brush to stick in the access holes in the nozzle to clear the tip. This I do after nearly every couple of sweeps of the AB over a piece I am spraying. So after a couple of passes I will stop spraying, dab the short bristled brush into all four openings in the nozzle end.
          Then after each colour I will flush through as per the H&S recommendation then top up with fresh mix. At the end of the session I will give the AB a more thorough clean.
          Not had any problems so I'm really very pleased with how it performs. As this is still my first year of using an airbrush I find this model quite refreshing after my Timbertech AB which splattered, and spurted often and needed a thorough clean after every colour!!!!
          • John
            • Mar 2004
            • 4618
            • John
            • Halifax
            As Andy says it’s a .45, but as far a I know that is only the needle cap, the needle is .04, they made the needle cap a little bigger to prevent blocking or tip drying. It’s a fantastic airbrush, certainly wouldn’t class it as the entry level, but it is.
            what PSI are you using?
            You could always add a bit more thinner, not all paints thin at the same ratio, or add a bit of retarder.
            www.scalemodelshop.co.uk
            • Bri62
              • Jan 2023
              • 1877
              • Brian
              • Widnes Cheshire
              Around 18-20psi gave it a good strip down clean and it seems better, found some paint residue around the air Vv
              • Waspie
                • Mar 2023
                • 3488
                • Doug
                • Fraggle Rock
                18-20 is usually where I operate. Fingers crossed Brian the strip down cures your problems with it. It is a great AB.
                • BarryW
                  • Jul 2011
                  • 6007
                  With Vallejo MA and other water based paint you do get very different experiences reported by users.
                  This largely comes down to humidity and how it affects the spraying of these paints. You need to experiment with what works for you with the use of retarder, thinner and air pressure combinations. I would suggest starting with a drop of retarder and then moving up the air pressure closer to 25psi. The needle should not make a difference as VMA works well with needle sizes over .3 and I have used it successfully with a .4 needle
                  It can be a lot of ‘flaffing around’ with these paints but if you don’t have a well ventilated spray area or a decent spray booth these are the better option. But don’t expect trouble free spraying, you will get to learn with experience how to deal with them, tip-dry will happen regardless on long spraying sessions.
                  That said, if you do have an extracting spray booth to get rid of fumes, I would suggest switching to lacquer based paint. You get none of the problems you experienced and a lot of advantages.
                    • 18873
                    Personally I find VMA needs more thinning (using their airbrush thinners) and a drop or two of flow aid to behave itself. It brush paints straight from the bottle, but certainly doesn’t spray that way. I use a .35 needle in my Iwatta at 15-20 psi, by the way.
                    • David Lovell
                      • 2186
                      Right I'm not going down the lacquer/ acrylics Road but if your just starting out sit down with some plastic picnic spoons cheap on flea bay ,a few sheets of printer paper and teach your self how to thin paint/set air pressure best for you ,you can be shown this but your the only person who can learn it. Its the old adage its not the golf club its the man behind it im afraid your be surprised a little practice makes all the difference.
                        • 18873
                        100% agree with this. Graph paper is quite good for practicing line and shape following as well.
                        • Andy T
                          • Apr 2021
                          • 3238
                          A kids paint-by-numbers book is good practice too, especially for multi colour camouflage patterns.
