Iwatalube, necessary or not?
  • Watto
    • May 2024
    • 62
    "Ay up team" I was wondering what your thoughts are on using the lubricant that is supplied with Iwata airbrushes? I've heard folks say it isn't necessary and others say " it's supplied for a reason "
    I personally use it every time I use my airbrush but, wondered if others do?
    Also, what can be used when the little tube runs out, the cost of replacement seems quite high so is there a cheaper alternative?
    Watto.
  • BattleshipBob
    • 6783
    • Bob
    • Cardiff
    I always use it, after cleaning the needle I put a tiny blob on kitchen roll and draw the needle through it. It's supplied for a reason.
    • Andy T
      • Apr 2021
      • 3238
      I wouldn't use the word necessary as I rarely use it, but it can help to keep things moving smoothly.
      I guess for me it's a carry over from the day job. Some of my Iwata spray guns are over 20 years old, used & abused daily, and hardly ever get lubed (or stripped for cleaning)
      It's funny that they supply it with their airbrushes. My latest pair of Iwata guns were £600 each and I didn't get any :tears-of-joy:although I did get a Christmas cracker style screwdriver for changing the battery lol
      Edit: As for the cost, using a drop or two each time it should last a very long time.
        • 15631
        I use it only after the airbrush has had a thorough clean. After an ab session I normally just flush through with an appropriate cleaner but I use the lube if I've removed the needle.
          Somebody must have forgotten to put that into the box of the one I bought a few years ago, then
            • 18873
            Originally posted by Jakko
            Somebody must have forgotten to put that into the box of the one I bought a few years ago, then :sad:
            I got two with mine . Usually use it described by Bob…..it’s lasted many years so far.
            • Tworrs
              • Jan 2022
              • 1978
              • Garry
              • New Zealand
              I rub a small amount onto the whole needle, after every clean, that way it gets to the seals as well.
              I've had my two Iwata's for about 15 years now, and they still work as they did when I bought them, so I must be doing it right,
              • Watto
                • May 2024
                • 62
                Looks like the general consensus is that it does get used by a fair few modellers.
                What about other lubricants?
                Does anyone have an alternative?
                I’ve read that the Iwatalube is glycerin based…
                  • 18257
                  Never used a lube in an airbrush. Acrylic paint thinners and cleaners have a 'soap' in them (most in Cleaner) so not needed.
                  Enamel paints I clean up with White spirits which again are self lubing to a point.
                    • 15631
                    Personally I would only use a lubricant designed specifically for airbrush use. I would never risk WD40 or sewing machine oil etc
                    • Andy T
                      • Apr 2021
                      • 3238
                      I think Badgers version, Regdab, works out much cheaper than the Iwata.
                      I don't know if it's as good but at least it's made specifically for the purpose, rather than risking something else.
                        • 18873
                        Mine’s called superlube, since rebranded as Iwatta lube. Quite pricy really, Redgab looks to be about half the price.
                        • colin m
                          • 8727
                          • Colin
                          • Stafford, UK
                          I’ve used WD40 and it’s never caused a problem. However, I am just talking about wiping the needle with a cloth dampened with the stuff, not a full on, full power spray.
                          • David Lovell
                            • 2186
                            I thought long and hard over this you'll all be more than pleased im not getting involved. Mr Slobby
                            • JR
                              • May 2015
                              • 18273
                              Really Dave I am surprised
