Airbrush, (Fengda) help!
  • Waspie
    • Mar 2023
    • 3488
    • Doug
    • Fraggle Rock
    I have acquired a pair of A/B's from Guest. One, the Gaahleri pistol grip A/B I have managed to find and download the manual so I know what and how to clean and lube.
    The other, a Fengda FE186 A/B from a package that did include the compressor has no manual. The Fengda web site is good if you want replacement parts but no manuals. (Or I'm being seriously dumb - don't answer that!!!!) :smiling3: Anyone have a link that could post, or a manual they wouldn't mind copying as a .pdf file and emailing me - pretty please!!
    It isn't life threateningly important as I've already stripped them both down and re-assembled. (And yes they ARE working now I've put them back together!!)
    I like to have them, (manuals), incase I have a brain phart!!!
    Thanks in advance.
    Doug
    • 15631
    I think there are a few videos on YouTube which might help. Just search Fengda airbrush.
    • Scratchbuilder
      • Jul 2022
      • 2689
      Thanks in advance.
      Doug
      PM me your email.
      Mike
      • Waspie
        • Mar 2023
        • 3488
        • Doug
        • Fraggle Rock
        Originally posted by Jim R
        I think there are a few videos on YouTube which might help. Just search Fengda.
        Roger doger Jim!! Cheers.
        PM me your email.
        Mike
        On it!!
        Incoming.
        • Waspie
          • Mar 2023
          • 3488
          • Doug
          • Fraggle Rock
          Scratchbuilder PM sent.
          • Scratchbuilder
            • Jul 2022
            • 2689
            Got it
            • JR
              • May 2015
              • 18273
              Wow that was fast , sometimes it's takes hell of a time . Oh Wibble I like the new address, " peoples republic of the UK
              Yours Wobble .
              • Scratchbuilder
                • Jul 2022
                • 2689
                Yours Wobble .
                Got to suck up to our new leader Sir T-T, he of the Liemore party....
                • Waspie
                  • Mar 2023
                  • 3488
                  • Doug
                  • Fraggle Rock
                  Has Terry Thomas gone all political!!!!!! :rolling:
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    Hope not, he died some time ago. And with that it is goodnight from him.....
                    • John
                      • Mar 2004
                      • 4618
                      • John
                      • Halifax
                      Our own brand airbrushes are made by Fengda, we don’t have many left in stock but if yours is like any that we still have I can send you a manual
                      Buy our Scale Modelling Airbrushes. Using an airbrush will speed up the process when painting your models & give you outstanding results. Shop today!
                      www.scalemodelshop.co.uk
                      • Waspie
                        • Mar 2023
                        • 3488
                        • Doug
                        • Fraggle Rock
                        Cheers John, I’ll have a butchers when I can access my laptop.
                        • Waspie
                          • Mar 2023
                          • 3488
                          • Doug
                          • Fraggle Rock
                          John , looked at the link, sadly nothing resembling the model I have. Fortunately, Scratchbuilder aka Mike emailed me a .pdf of what I needed.
                          To be honest, I have now had the thing apart so many times today, cleaning and testing - I'm very comfortable with its innards now.
                          Which leads me on to its future usage, it will now be my varnish A/B. tested all three needles and the 0.2mm splatters everything no matter how I set it up, the unmarked needle simply doesn't look 'nice' when spraying. However, the 0.5mm needle nozzle combo gives a really good spread without splatter or anything!!
                          The bonus for me was the hose that came with it had a quick release connection, so I now have all thee A/B's fitted out with the quick release fitting!! :thumb2:
                          Thank you all for your replies and help - all gratefully received.
                          • Scratchbuilder
                            • Jul 2022
                            • 2689
                            Check the very tip of the 0.2 needle, run the point through your finger and thumb and you may find that the very tip is bent (hard to see with the eye) If it is then lay the needle on a flat surface and with some fine wet n dry paper 400 or finer. Rotate the needle and sand the tip at the same time.
                            • Waspie
                              • Mar 2023
                              • 3488
                              • Doug
                              • Fraggle Rock
                              Ahh, I did run my finger over the tip and when I looked at the tip with my magnifying goggles there is a very - very fine kink right at the tip.
                              Thanks for the - wait for it!!!! 'Tip!!! Oh that was bad!!!! Seriously, thanks Mike, I'll have bash at it tomorrow.
