Tomorrow is the day when i loose my cherry, so to speak.
But i need to ask some really simple questions. Well, simple if you know the answer i suppose?
Primer - i currently use aerosol primer. I don't see any reason to change this. Its very convenient, virtually no cleaning, and the result seems very good.
Colour - i've decided to try with acrylics, specifically model air, as i already have a few which i use for weathering etc. I asume that for airbrushing that its diluted with water? Can the brush then be flushed with water, or should i use white spirit/turps?
I will want to use enamels at some point, for some car kits that i fancy. I guess that this is thinned with......well, thinners?!!! Or can i buy a big bottle f something at B&Q that does the same?
I know that for cleaning i need to use reamer (i'm getting there!! Slowly!!)
Thanks for the help.
