Hi all,
Following a session of air brushing today it was time for a strip and clean up.
I empty the cup of any left over acrylic paint, drop in some Tamiya thinners and stir with a small brush and pour the mix out, next is a couple of cups of Vallejo airbrush cleaner and blast through at 25psi. When I strip the nozzle off and the needle out there is still some significant paint residue on the needle and to be honest the cup is still showing signs of paint staining.
I'm not too sure with the Vallejo cleaner to be honest as it just doesn't seem strong enough to give a good clean. I tend to finish off the clean with some Spraycraft cleaner which although very good it requires a good mask and ventilation!
Has anyone tried the Medea cleaner and have any views on it's effectiveness. It says it's "strong" in the advert and has no odour so could be the best of both worlds.
Also while on the subject, could someone maybe put a list together as to what to cleaner to use with what paint product? I'm getting a little confused with IPA for this, cellulose for that, white spirit for other stuff, I just don't know what to use for the best with different paint/varnish products and what may damage seals in the airbrush or not. Would be very much appreciated :thumbs-up:.
Atb,
Colin.
Atb,
Colin.
