CR and 0.2mm? Can be done!
    Chaps, just a heads up, Iwata list a 0.2mm nozzle and cap (only) for their BR and CR A/B's. I enquired about what you do about the needle etc and they said "Use everything else from the 0.3mm kit". You would need to use MA or life colour but they say the A/B is okay with the set-up. So, If you fancy a try at even finer lines with the CR, it can be done quite cheaply (if you already have the 0.3mm kit).
    Not sure I'm up for tha challenge, yet.
    Rick.
    BTW, I LOVE my CR 0.3mm, its like real love but without the hoovering...
    Brilliant, must tell the missis....................there again, maybe not!
      Ooooo, .2 mm Mmmmmmmmmm interesting
      • stona
        • Jul 2008
        • 9889
        Good heads up on the paint. A lot of model paints will be hard to spray through such a narrow nozzle.
          They said that the Tamiya is a definite no go for 0.2mm but MA and LifeColor will be good although not stated as such by the manufacture in the case of LifeColor. I cant say I have the need at the mo, but maybe next year when I have some really small stuff to do.
