Any help here would be appreciated as I have virtually run out of ideas.
Getting after about a minute airbrushing blobs of paint. Tracked that down easily to paint building on the bottom edge of the needle guard at the front.
OK I clear with a cotton bud accompanied by a few choice rustic English words. Same again on the next cycle.
So have changed needles & nozzle .2 size .Also changed size of needle & nozzle to .4 Also used both the airbrushes I have.
Cleaned the brush well top to bottom. Cleaned nozzles. Noticed that paint has been creeping up the needle.
Tried different compressor settings. 15 to 24 PSI.
Beginning to suspect the compressor (no tank) is pumping varying pressures although this is not manifested by the pressure dial. Noticed that every hour or so it tops itself up for a couple of seconds which must mean a slight loss in pressure. Have another compressor & will try that later.
Think that is all the clues I have eliminated. Just to finally say this happens with Vallejo primer paints & varnish. All using a Harder & Steenbeck Evolution series brush. Also really final that the paint film is fine until the spots. Ah Treasure Island "Jim lad" beware the black spot at the Admiral Benbow.
