Vallejo Model Air Psi
    Hi, just got my new compressor and airbrush and am about to paint my revell westland wessex. I have some of the model air colours and wondered what psi I should spray at. On vallejos website it says 20-25 but that seems way to high.
    Any help would be appreciated
  • BarryW
    • Jul 2011
    • 6009
    I tend to spray them generally about 15-20 psi with a 0.2 Evo.
    • John
      • Mar 2004
      • 4622
      • John
      • Halifax
      I agree with Barry round the 15psi mark should be fine, but it also depends on your airbrush, Iwata work better at 15 which is what I use.
      www.scalemodelshop.co.uk
        I agree with John & Barry.
        A lot depends on as both Barry & John mention the size of your needle nozzle. I generally keep up the pressure for .2 needle & lower for .4.
        Also if you are thinning Model Air. I generally thin 25 to 40% depending on what I am airbushing. With the heat at the moment the paint goes off as it almost leaves the brush.
        Best I found is to get some empty plastic bottles & practice on these for hours yes hours but it is well worth the trip. Use different settings to see the effect.
        If your compressor is a tankless type I found with mine that the pressure gauge dropped from its idle position when I started using the brush & pumping air. Do not have the same with the new tank type I now have.
          i think it depends in what your doing too.
          I've been doing so free hand close detail work on a 1/72 kit and so that i dont get any "splat" or overspray i dropped the psi right down to 10.
          normally i have it somewhere between 20 & 25 though.
            15-20psi with an Aztek. I found that anything above 20psi causes the nozzle to block very quickly.
