I would not put anything into a wall or the roof space. Think you are asking for problems both fire & contamination building up over time. It will taint all it comes in contact with. White spirits that is.
I modified mine with a bathroom ventilation ducting from B & Q. Can you vent with ducting up into the roof space then out through the roof tiles. You can get roof outlets especially for this. Or if your eaves overhangs the outside wall you may be able to put a hole in the sofitt & fit a duct outlet. B & Q again.
LAurie
LAurie
