Air brush problem
    • 22769
    Air brush problem
    Ok when cleaning my Iwata revolution cr air brush i dropped it into the sink and bent the nozzle ( needle not in ) so i bought a new one from John ( great service by the way ).5mm and now when i use it hardly any paint comes out. Any ideas ? Its been cleaned before the new nozzle whent in and after. When i say hardly any paint you have to hold the brush very close to the model for the paint to go on
  • John
    • Mar 2004
    • 4622
    • John
    • Halifax
    I've been trying to think of an answer to this and I can't, I take it you have no air leaks and your pressure is around 15psi
    www.scalemodelshop.co.uk
    • rickoshea52
      • Dec 2011
      • 4076
      • Rick
      I don't know the answer to this question but I know a man who does. The Iwata customer support service is excellent. They have a technical expert who can provide help via email (they are based in West coast America) or you could look up their tutorials on Youtube.
      When I get a moment I'll see if I can find his email address in my email vault.
      • AlanG
        • 6296
        One obvious thing i would check is, is the nozzle actually a 0.5mm nozzle? Has this one not been packaged up correctly or made correctly?
        • rickoshea52
          • Dec 2011
          • 4076
          • Rick
          I don't know the answer to this question but I know a man who does. The Iwata customer support service is excellent. They have a technical expert who can provide help via email (they are based in West coast America) or you could look up their tutorials on Youtube. When I get a moment I'll see if I can find his email address in my email vault.
          My problem was similar to yours though not after dropping it. I had cleaned my Iwata Eclipse thoroughly, or so I thought and had air to the brush but not from the nozzle. Kirk Lybecker at Iwata had me remove the nozzle cap and lo' there was dried paint that I had missed. Nail polish remover cleaned it out and the brush worked fine after that.
          If this doesn't help try contacting him directly - kirkl@iwata-medea.com or info@iwata-medea.com.
          Search Youtube for his tutorials using keywords "airbrush cleaning lybecker" and useful maintenance tips.
            • 22769
            I was thinking the same allyne but how can you tell ? the package say's .5mm
            • stona
              • Jul 2008
              • 9889
              I'd disassemble the brush and give everything a thorough clean. I'd then reassemble and make sure all the joints are sealed (not overtightened!) especially the head cap which may be your problem. Give it a go,just spray some water,and note any problems.
                • 22769
                My problem was similar to yours though not after dropping it. I had cleaned my Iwata Eclipse thoroughly, or so I thought and had air to the brush but not from the nozzle. Kirk Lybecker at Iwata had me remove the nozzle cap and lo' there was dried paint that I had missed. Nail polish remover cleaned it out and the brush worked fine after that. If this doesn't help try contacting him directly - kirkl@iwata-medea.com or info@iwata-medea.com.
                Hi Rick i get air through the nozzle as normal when i depress the button its when i pull it back for paint that very little comes out and you need to be real close to the part your spraying
                  • 22769
                  I'd disassemble the brush and give everything a thorough clean. I'd then reassemble and make sure all the joints are sealed (not overtightened!) especially the head cap which may be your problem. Give it a go,just spray some water,and note any problems.Cheers
                  Just done all that Steve it works well with just water ( but still not as good as before ) so tried again with paint ( Vallejo model air ) back to hardly any paint so thined it down even more work better but as with the water not as good as before i damaged the nozzle so i'm now starting to think it may be a .3mm nozzle in a .5mm nozzle bag/or the new nozzle is damaged in some way. STUMMPED
                  • stona
                    • Jul 2008
                    • 9889
                    What does it spray like with NO needle fitted?
                    • John
                      • Mar 2004
                      • 4622
                      • John
                      • Halifax
                      If it stops spraying when you pull the needle back it won't be the nozzle and the tip of the needle wouldn't go through the smaller nozzle, when you push the lever down does it push the valve down properly where the hose is attached
                      • rickoshea52
                        • Dec 2011
                        • 4076
                        • Rick
                        I'd email Iwata's customer support for help. You may even get a reply tonight considering the time zone difference.
                          • 22769
                          What does it spray like with NO needle fitted?Steve
                          It sprays very quickly Steve
                            • 22769
                            Going to give them an email today Rick
                              pap695 said:
                              "Hi Rick i get air through the nozzle as normal when i depress the button its when i pull it back for paint that very little comes out and you need to be real close to the part your spraying
                              "it works well with just water ( but still not as good as before )"
                              Logic (not always a useful tool) says that, in view of the emboldened text, that the paint path is blocked (from cup to nozzle), paint being more viscous than water). You could use one of those dental stick brushes from nozzle to cup to clear it. I had to do that recently.
