After cleaning the airbrush and assembling it again, I blow some airbrush cleaner (or water) through to check the flow. The cleaner (or water) bubbles up in the well containing the trigger (NOT in the colour cup which seems to be the usual beginner problem).
By cleaning I do this:
Clean the cup with a good quality paper towel, add some cleaner (or water) to the cup and brush the bottom of the cup, pour out the mixture and repeat perhaps another twice until clean;
Add Vallejo "Airbrush Cleaner" (or water) to the cup and blow compressor air through, repeating until it blows clean;
Remove the nozzle and the two caps and withdraw the needle from the front and thoroughly clean it;
Put the nozzle and the two caps in cleaner, agitate and leave to soak for about 10 minutes or more while continuing to clean the airbrush as follows;
Insert the little bottle brush into the passage between the front and the bottom of the cup and add cleaner to the cup;
Agitate the brush in and out, pushing it in a little so that its tip disappears beyond the bottom of the cup (by about 5 mm). Repeat cleaner and brush until the brush shows clean;
Use the little bottle brush on the nozzle and the two caps to thoroughly clean them;
Re-insert the needle from the front and reassemble the airbrush and confirm a good flow with cleaner (or water);
At this stage cleaner (or water) immediately bubbles up in the well containing the trigger. I have to remove the trigger and dry the well.
This bubbling up in the trigger well has now happened four times in a row, and once about several cleanings ago, since I got the AB four weeks ago (a good quality one with PTFE seals or whatever they are called, the good ones).
I have noticed that when inserting the needle from the front there is a small resistance when it starts to enter the end (nearest the front) of the well containing the trigger. Presumably there is a seal there. Therefore, when cleaning as above, to prevent the cleaner (or water) running back into the trigger well (the needle is no longer there to block the seal) I keep the front of the airbrush pointing downwards at all times when cleaning. But the cleaner (or water) still bubbles up in the trigger well. There is definitely no sign of water in the hose or the compressor air supply (and in any case the problem occurs only immediately after cleaning).
Could you please tell me why this is happening and how to prevent it?
Thanks.
Thanks.
