Hello chaps!
I've got a new airbrush and to begin with it sprayed beautifully.
However, it started blocking on a regular basis, normally while spraying a model! Just tonight I was making good progress and then it just stopped spraying paint. I took it apart to clean it and the end of the nozzle with the miniature rubber gasket (the piece I can undo using the special mini-spanner included with the a/b), is jam-packed.
The needle won't go back through because it's so blocked. I tried soaking it in a/b cleaner - at great peril to the rubber gasket - but still no joy............. Ahhhhhhhhhhhhhhhhhhh!!! Please HELP!
