I airbrushed a final matt varnish, Tamiya Flat XF-86, undiluted, 20 PSI, 0.4 needle, (which is on Tamiya Clear Varnish which is on Xtractylix RAF Dark Earth and RAF Dark Green). The result is very good except for a white deposit in several panel lines which was not there before the matt varnishing. (I have not applied any weathering to this model.) I tried to remove it gently with a pin but no luck. Please see the photo.
I have hidden the white by painting with a minute brush loaded with the (water) thinned appropriate camo colour (hoping for it to wick but it didn't) and all now seems well, (except for the area (in the picture) which is a bit messy where I used the pin.
Any ideas why the white deposit please, and why just here and there?
[ATTACH]64401.vB[/ATTACH] (There is a hair near the bottom of the photo !@%$ยฃ&*)
[ATTACH]65604.IPB[/ATTACH]
