Help please
  • mossiepilot
    • Jul 2011
    • 2272
    Help please
    I've been practicing my airbrushing on a cheapie kit before going on to do my Starfighter, and the air brush is doing something strange.
    When the cup is empty, and I have the trigger depressed but not pulled back, so theoretically no paint should be able to come out, I get blobs of thin paint being blown out with the air and splattering onto the painted surface. I use air from the brush to dry the paint a little faster.
    My airbrush is one of those cheap chinese copy jobbies with a 0.3 nozzle, that comes as part of a set, compressor, hose and two airbrushes, I know, I know, but I keep it as clean as I can, dismantling and using airbrush cleaner after each session.
    Has anyone any idea why it splatters paint like this, cos I'm stumped! and I don't want to use it on the Starfighter until I've got it working.
    BTW, I'm using vallejo colour paint, thinned til it looks like milk, about 60/40 I think.
    Tony.
    Hi Tony. The residue of paint is probably in the needle tunnel.
    Seems to me that the needle is not forward enough into the nozzle & there is a gap enough to let paint through. If you loosen the screw holding the needle to the airbrush gently edge the needle forward a fraction to seat the needle neatly in the nozzle.
    Another possibility is that a small amount of paint has hardened on the edge of the needle or in the nozzle itself which is preventing the needle seating as it should in the nozzle.
    Failing all of that it may be that the needle or nozzle is damaged & the needle cannot seat correctly to block the needle nozzle bond.
    • mossiepilot
      • Jul 2011
      • 2272
      Thanks Laurie, I don't think it's damaged, everything looks as it did when I first got it, I think, this is my first one and I'm still learning what's what. I'll give it another clean and see how it goes. One thing I did notice,after I had cleaned it, at the bottom of the cup there seemed to be a "residue" don't know how else to describe it.
      Is there a way to clean the paint nozzle so all the paint is removed, I have to wear my magnifiers just to see the d""b thing and seeing inside it is almost impossible.
      Tony.
      • rickoshea52
        • Dec 2011
        • 4076
        • Rick
        I have used nail varnish remover before. Left to soak in a small amount cleared a blockage that I had caused by dried varnish.
        • stona
          • Jul 2008
          • 9889
          Interdental brushes are your friend for cleaning nozzles etc. Moisten in cellulose thinners (the cheapo stuff from Halfords or similar) which will shift anything.
          A word of caution. Don't be tempted to spray those thinners through your airbrush unless you are sure that the various seals, o rings etc can tolerate it.
          I think Laurie has isolated the most likely causes of your problem above.
          • mossiepilot
            • Jul 2011
            • 2272
            I used it with some Johnsons wax ( Klear) a couple of days ago could that be the problem and will the nail varnish remover sort it out and how long do you soak it for, is overnight too long?
            cheers
            tony.
            • mossiepilot
              • Jul 2011
              • 2272
              Thanks Steve, never used cellulose thinners before, and with the brush being what it is, I think all the O-rings are probably rubber, not cellulose thinner resistant, the one on the nozzle certainly looks like rubber. Are there any precautions I should use to prevent accidental damage.
              cheers
              Tony.
              • tanktrack
                • Jun 2012
                • 1429
                it is probably the klear that has hardened I always run a min of 2 full cup water flushes then a Vallejo thinner , Vallejo cleaner and the a water again , klear can stick like muck to a blanket otherwise . like the guys say I would be careful about cellulose as it will melt the rings , I would soak it in water overnight and it may soften the stuff inside .
                steve
                  Originally posted by \
                  it is probably the klear that has hardened I always run a min of 2 full cup water flushes then a Vallejo thinner , Vallejo cleaner and the a water again , klear can stick like muck to a blanket otherwise . like the guys say I would be careful about cellulose as it will melt the rings , I would soak it in water overnight and it may soften the stuff inside .steve
                  Yes, varnish is known to need more vigorous cleaning. It is designed to form a wear-resistent (and therefor probably hard) surface
                  • mossiepilot
                    • Jul 2011
                    • 2272
                    Thanks Steve and Steve, I gave it a good clean last night and it sprays water OK but I haven't put any paint in it yet, I'll stick the nozzle in some water, would hot/warm water be better.
                    Tony.
                      What I do Tony is to get a small egg cup or paint palette fill it with Vallejo Airbrush Cleaner & leave. If you use water first make sure It has all gone bere the Vallejo as the water will dilute the cleaner.
                      • mossiepilot
                        • Jul 2011
                        • 2272
                        Sorry Laurie,don't understand, do you mean blowing the vallejo cleaner through the brush after soaking the nozzle in water. Cheers
                        Tony.
                          I have a couple of videos that might help.
                          The first will enable you to strip and check the brush to see what type of needle seal it's using, a lot of the cheap chinese brushes, (like mine in the video), use Teflon type seals. The needle seal will be rubber but depending on the brush, it may, (again like mine), seal without.
                          This is handy in knowing A - You can spray through Cellulose thinner and B- You can soak / clean with Cellulose thinner.
                          The second video is a 'how to' on giving a thorough clean using the appropriate thinner.
                          The only new addition is the use of an interdental brush for the feed tube from the cup to the nozzle and I use a very very fine beading needle to check the nozzle is clear after cleaning with the paintbrush and thinner.
                          Video1
                          Video 2
                          • mossiepilot
                            • Jul 2011
                            • 2272
                            Thanks Mike, the videos are really useful.
                            I will admit I still find air brushing a little scary, so taking it slow and taking my time.
                            Thanks again,
                            Tony.
                            • Dave W
                              • Jan 2011
                              • 4713
                              The fact it's a cheap airbrush shouldn't be a problem.Ive got a cheap Chinese copy and it sprayed brilliantly until I lost the tiny 'O' ring seal somewhere in my shed .Havent been able to get a replacement seal so bought an Iwata airbrush instead
