I have sprayed (by AB) the underside of the wings and the fuselage with Vallejo semi-mat varnish, thoroughly shaken with a rattle nut. Room temperature for everything (varnish, thinner, AB and the model parts). There are many tiny white spots on the parts, smaller than a pinhead. I diluted with about 10% Vallejo thinner, 18 PSI, sprayed just to wetness to achieve cover. The spots appeared immediately I started spraying.
When I used Tamiya matt varnish on my 1/72 Spit I got white colouring collecting in the panel lines here and there. I understand that matt and semi-matt varnishes contain a white powder which prevents a shiny skin forming.
Once thoroughly hardened (24 hours) I will consider using a micromash cloth to remove the spots and re-spray.
But what caused the spots, and what would be the best way to remove them, and to prevent them re-appearing when re-spraying?
[ATTACH]73884.IPB[/ATTACH]
