I have often used masks and never had paint creep. Initially I did have a problem with the frame paint coming away with the masks but that is largely over come by:
1/ Cleaning the canopy with i.p.a. first.
2/ NOT using primer as I find it a bit more rubbery than my normal Vallejo
3/ By carefully using a cocktail stick around the edges of a frame, pushing the mask into the centre first.
You do have to burnish down around the edges though.
The main problem with masks (and Tammy tape) is glue residue. These days I mostly use Parafilm M which is a large initial outlay but longer term is a very cheap option, it needs practise too..... if you are not careful you can score the transparency when cutting around the edges but there is no glue residue at all.
