Using oil washes
  • Alan 45
    • Nov 2012
    • 9833
    Using oil washes
    I've had a crack at oil washes today and I don't think it's that bad for a first attempt and maybe on something bigger I think it could look quite good
    Comments please [ATTACH]88869.IPB[/ATTACH]
    [ATTACH]88870.IPB[/ATTACH]
    It could be me, but I can't really see much there! Its not coming through in the photo's Alan is what I mean.
    • Alan 45
      • Nov 2012
      • 9833
      Is this any better [ATTACH]88875.IPB[/ATTACH]
      [ATTACH]88876.IPB[/ATTACH]
      [ATTACH]88877.IPB[/ATTACH]
      It doesn't look like it's going to show on the photos , in real time you can see it , oh well I'll finish the model and then see how it looks
        Looks very well to me.
        You thinned with white spirit?
        The best advantage of the oil washes is you can play with them...explain, you did a "normal" brown wash, but if you want can add, now, some dark brown wash (only on the most darkness places) and then, with a clean brush difuminate all the wash effect! The final result is a very nice and showy wash
        • Alan 45
          • Nov 2012
          • 9833
          Originally posted by \
          Looks very well to me.You thinned with white spirit?
          That's the method I'm trying to use mate , I put a line in crease and then push in with a dry brush , this is my first attempt but I think I'm making work for myself as it's a small kit but I pleased with the effect of the blend but it maybe it looks out of scale on this so it might need a bit of a dry dab of the original colour
            Just remember the dry time on the oil colours is much longer...so you have to wait some time to add the second wash over. You will work much better then!!
            On the acrylic and enamels is different
            • Alan 45
              • Nov 2012
              • 9833
              Just remember the dry time on the oil colours is much longer...so you have to wait some time to add the second wash over. You will work much better then!!On the acrylic and enamels is different
              Yes I know mate I've put a wash on some faces this morning and it's just as wet now , I'll leave this until tomorrow and carry on then.
              What's the best mix for skin tone ?
                I use a red one (not a red passion ) and just add some brown drops. The mix must be very thinned for a soft effect, so you can add one or more washes over the first one.
                • Alan 45
                  • Nov 2012
                  • 9833
                  Thanks mate I'll give it a try
                    Better paint a plastic piece with the skin colour before, and then add the wash!! Until you find the correct one!!
                      I can see a bit more of it in the 2nd photos Alan. What I'm wondering is the model doesn't look very shiny, so I'm thinking you didn't apply a gloss coat?
                      • Alan 45
                        • Nov 2012
                        • 9833
                        I've been painting the face white then adding the wash then I will add the flesh as a highlight , I had a go the other night and it comes out looking good
                        • Alan 45
                          • Nov 2012
                          • 9833
                          No mate just the matt acrylic then the wash and sort of push it into the crease so it looks dark in the crease but sort of feathers out thinner so it looks like it's blending ,
                          As the kit is small and the pics are close up it doesn't give it just but if you look at it from a couple of feet it looks ok , not perfect but it's a good start , I can't do it too dark as it wouldn't be in scale due to size of it
                          • monica
                            • Oct 2013
                            • 15169
                            I can pickup were the wash has gone on, and looks fine to me, and remember that it dose take a few go,s with
                            diffidence shades , as how Polux said is the same way i tend to do but I start with a light wash and that lets me
                            see were i do need ,the wash to be, and its easy to darken than lighten ,but thats just me
                            • Alan 45
                              • Nov 2012
                              • 9833
                              Well I haven't had much success with this little armoured car so turned my attention to an old build
                              This is what I did the first time
                              Oh well I tried to edit it and it still didn't work looks like it's going to have to be the laptop from now on
