Hi peeps, general brush painting question.....
I've watched a fair few YouTube vids and read a fair bit on painting now, but its mostly biased towards air brushing.
I think I have the basic brush painting sequence, but would like your opinions/thoughts, thanx.
NB: for whats its worth I will be mostly building military vehicles, with maybe the odd civilian vehicle (motorcar/motorbike), and maybe the odd motor boat, etc,
From what I've gathered the painting process should be as follows:
1. Prepare model or part to be painted, remove from sprue, assemble/sub assemble, glue, clean up, sand, fill, etc.
2. Add prime coat. Prepares surface for painting and shows up any minor defects, gaps, etc.
3. If necessary fill any gaps, etc.
4. Add initial top coat, can be more than one coat, several thin coats better than one thick coat.
5. Add gloss varnish/lacquer coat. (Easier to apply transfers on gloss coat and protects paint and allows washes to flow better).
6. Apply transfers.
Q: should there be another gloss coat applied after transfers but before weathering?
7. Add weathering effects, washes, pigments, etc.
8. Add final flat varnish/lacquer coat to leave a non glossy finish and protect weathering.
Have I missed anything?
Cheers folks.....
6. Apply transfers.
Cheers folks.....
