Best method for motorcycle seat?
  • pjgtech
    • Dec 2023
    • 727
    • Peter
    • Swale Kent UK
    Hi, currently only just started on a 1:12 motorbike build, but the seat is just a shiny plastic black.
    What would be the best method to get a more realistic worn seat type look?
    Was thinking of maybe lightly sanding it down then some sort of black leather type paint.
    Nb: I do have a leather and wood paint set, but I think the leathers are just reds / browns, so no black.
    • 18868
    Was the original seat on the Blackbird leather though? If it’s vinyl then a good way to replicate it is to polish up the black plastic using Tamiya polishing pastes. I’ve done that on a bike build before and it looked quite realistic.
    • pjgtech
      pjgtech commented
      Editing a comment
      Hmm, good question, I think its vinyl, and its already quite shiny, a bit too shiny IMHO, hence why I thought maybe knock it back a bit.
  • PaulTRose
    • Jun 2013
    • 6406
    • Tattooine
    Rattle can of matt black
    Per Ardua
      • 18868
      Polishing it actually gives it that vinyl “Sheen” texture, not a high gloss. At 1/12 scale texture can be important. You’d get away with paint in 1/35, but bikes are bigger.
      • Nicko
        • Apr 2019
        • 1347
        • Nick
        • East Anglia
        You could achieve some texture by stippling some fairly thick matt paint ideally a 'not quite black' and then just rub it between your fingers once fully cured to knock back the higher spots and also give an uneven glossier/matt look....
        Nick
