Great comment Dave, and very informative.
You also raise that perennial old chestnut of thinning ratios and pressures. It is entirely understandable that those new to airbrushing will seek advice about these most important criteria, whatever paints they are using. It is also important to understand that whilst some general and helpful advice can and always will be given by the members here, it is impossible to give exact or precise figures.
Whether you use acrylic or enamel paints, whichever brand and whatever airbrush set up, there is no substitute for experimentation. You just have to work out what works best for you.
For example, I spray my enamels thinned anywhere from 60/40 to 40/60, depending on the individual paint, at about 35-40 psi. I never measure anything exactly, I just go by 'feel' developed over the years. The compressor pressure is set on the standard cheap valve and must be, by definition, approximate. These valves are definitely not precision instruments! Others will find something completely different works for them, no matter which paints they use.
I do find as I read online forums that there is a tendency to over think the issues. As another example, I often apply the dreaded by many Luftwaffe mottle to my models and have read all sorts of advice on how to do this. Lower the pressure, thin the pint more, build up several coats etc, etc. I just spray it like anything else and I'm sure this would work for most other so called special finishes or effects
