Thinning for brush painting again...
    Hi. Issues with thinning enamels for good, even coverage, again.
    First coat using about a 70:30 ratio paint:thinner. [ATTACH]284171[/ATTACH]
    Next coat using a ratio of 1:1.5 paint :thinner
    [ATTACH]284173[/ATTACH]
    Quick picture of side panels. Bottom one is a 50:50 ratio, top is 1:1.5
    [ATTACH]284172[/ATTACH]
    Not sure where I'm going wrong. Keep getting brush marks and as you can see, drying thick in places.
    Have read loads now but just can't get it right. Perhaps it's the thinner I use? (White spirit). Or the thinning ratios? I obviously don't want it straight out of tin as will be too thick and will lose the detail on the model.
    Part of the problem is the fact that I just don't know what the consistency should be. Kinda going for a milk consistency, however I don't know if my brush marks are because of too thick, or too thin paint.
    This is my third real attempt at brush painting and as you can see, struggling
    Thanks
    Edd
    keep going, they'll magically disappear after a few coats!
      ...and don't be tempted to go thicker, cos then you'll lose surface detail.
      • col68
        • 1505
        As John said keep going with nice thin coats with plenty of drying time in between and they will disappear. I used to aim for 4 coats
        • spanner570
          • 15401
          Yes, just keep layering the thinned paint. What brush are you using? For areas such as you are painting, a flat (chisel) headed brush is a must.
