As title really, are hooked points on synthetic brushes inevitable? The general consensus on the web seems to be yes, with cheaper brushes succumbing sooner, but I thought I'd ask if there is anything I can do to lessen the issue.
I generally only use cheap brushes, so don't expect them to last forever, but Masters brush soap has been a revelation. Definitely one of those products that live up to the hype! My brushes definitely behave themselves more now that I clean them properly, but they all eventually hook over on the ends, even the couple of W&N Sceptre Gold I own have gone that way. I try and keep separate brushes for "rough" work like drybrushing and pigments, but even "normal" painting seems to curl the tips.
My options seem to be either keep replacing the cheap ones regularly, or, now that I'm a bit more disciplined and can look after them better, stump up for some posh pure sable brushes. Would the latter really pay off in the long run if I look after them, or are they wasted on a heathen like me? :smiling5:
I don't often do fine work, but there's nothing worse than needing a decent point and having to rummage through my collection to find something that isn't split or banana shaped!
