Hi everyone.
I would like to ask some of you experienced model makers about painting with enamel paint..
I first have to confess that I am not a modeller but a cyclist who has several older classic carbon Italian bikes and over the past couple years have been doing paint touch ups to small areas, chips and scrapes. Some of the work has been very intricate where a scrape has damaged a decal and the surrounding different colour paint or there is a piece of artwork with several different colours.
I have been using Revell enamel paints and Tamiya fine and finishing compound and yellow masking tape, 2000 and 2500 grit sandpaper and cheap Skipton fine detail paint brush set.
I’ve improved a lot having learnt from my mistakes but some things are still very annoying and I can go backwards and forwards over the same area for days or even weeks at a time.
I find painting a lager area say 1cm square impossible to apply paint evenly out of the tin so I end up with high and low spots.
Just as I wet sand it down to almost perfect, just a tad more and dam, a little spot appears with the different colour base paint showing through.
After painstakingly sanding down, the edge of the new paint often gets a shiny edge where it blends with the surroundings.
Would you use Tamiya fine and finish or just finish? Do you rub hard or gently? I’ve noticed a fair bit of paint on the cloth. Should I wait longer than 24 hours for paint to cure?
Any tips would be appreciated as this can be very time consuming and frustrating.
Apologise for the long post and thank you for your patience.
