How to paint thin outlines on a windshield
  • Modler bob
    • May 2022
    • 277
    Just wondering if there is a technique for painting the "metal" outlines on the cockpit glass front shield?
    I have some skinny brushes, but still, I manage to smudge it a tad, frustratingly. :disappointed2:
    My hands are quite stable
  • KarlW
    • Jul 2020
    • 1522
    You can use a cocktail stick to remove erant bits of paint, let it dry and scrape it off, doesn't damage the plastic.
    • colin m
      • 8740
      • Colin
      • Stafford, UK
      For any canopy work, I would mask, then paint, then add any chipping etc, whilst everything is still masked.
        • 18889
        Plus one on mask then paint.
        I mask the canopy off the model (it’s far easier to manipulate a canopy in your hand than a whole aircraft), then glue it in place and paint it with the rest of the aircraft.
        • zuludog
          • Mar 2015
          • 239
          Mask the whole canopy with masking tape
          Cut around the frames with a fine tipped blade, such as a Swan Morton #11 scalpel blade
          Peel off the tape from the frames
          Paint the canopy frames, and the rest of the model if necessary
          When the paint has dried, but not set absolutely hard, peel off the rest of the masking tape from the canopy
          OR -
          Cut masking tape into very narrow strips and line the frames with them, leaving the frames themselves exposed
          Fill in the rest of the canopy with tape or liquid masking fluid
          Paint the frames, and the rest of the model if necessary
          When the paint has dried, but not set absolutely hard, remove the masking from the canopy
          OR -
          Paint the frames as well as you can with a fine brush, but don't worry too much if it spreads slightly onto the canopy
          When the paint has dried, but not set absolutely hard, scrape off any excess paint with a cocktail stick
          It helps if you trim the end of the cocktail stick into a very small chisel shape
          This method is known as 'paint and scrape'
          Practice & experience will show you how set/dried/cured the paint needs to be
          You can get canopy masks for some kits
          Search YouTube for 'painting model aircraft canopies' ; there are several videos
          • JR
            • May 2015
            • 18273
            OR -
            OR -
            Good points there , I'll try the last method on my Mossie, thanks .
            • zuludog
              • Mar 2015
              • 239
              Oh, a couple of points I forgot -
              If you remove the tape or scrape while the paint is dry but still soft, the paint is less likely to chip or lift
              Sometimes it helps if you dip the cocktail stick in thinners when you scrape
              • JR
                • May 2015
                • 18273
                Thanks , noted .
                  • 18889
                  If the paint is acrylic, stubborn overpainting on a canopy can also be removed using a fine brush that is damp (not wet) with airbrush cleaner.
                  • Modler bob
                    • May 2022
                    • 277
                    Great stuff.
                    Thanks for all the replies, given me good ideas, especially masking the whole canopy etc (cheers zuludog)
                    • Modler bob
                      • May 2022
                      • 277
                      just looking around and wondered if this is any good to clean off paint that has been on the canopy for two days?
                        • 18889
                        I wouldn’t bother with it Bob. Just sharpen a toothpick to a chisel edge and use that to scrape the paint off. The secret is to scrape the paint off with something harder than the paint, but softer than the canopy, and not to let the tool dig in.
                        • Modler bob
                          • May 2022
                          • 277
                          Thanks Tim, I'll take your advice and chisel the smudged paint off (hopefully )
                          • Modler bob
                            • May 2022
                            • 277
                            works a treat Tim cheers, another tool for my beginner's collection
