Matt varnish issues
  • Jad
    • Jan 2023
    • 47
    Matt varnish issues
    As a complete newbie, I’m just coming to the end of my first model in 45+ years and I’ve really enjoyed the experience,
    But having brush mark issues with VMS Matt Varnish.
    I’ve tried without thinning and thinned and still having the problem.
    Any help appreciated ?
    • 15633
    It's a real shame. I am generally a big fan of VMS products. VMS Matt varnish does airbrush well but I have not heard how it performs when brush painting although it does dry very quickly so maybe the brush marks you have are due to the varnish drying before it can level out and so leaving the brush marks. Just maybe adding a retarder could help but test it first.
    We have all had similar issues but when it happens at the end of a build it seems so much more disappointing.
    • Jad
      • Jan 2023
      • 47
      I tried airbrushing with 0.5mm needle thinned and un thinned and wouldn’t go through the airbrush
        • 15633
        I'm sure you did but it needs shaking/mixing really, really well. Maybe it's a duff bottle :thinking: Can't help beyond that, sorry.
        • Jad
          • Jan 2023
          • 47
          Ok will try again. I did mix in the cup so perhaps do outside
          • adt70hk
            • Sep 2019
            • 10400
            Can't help as I don't use it but a YouTube modeller by the name Night Shift swears by it ... I'm sure he did a guide on it a couple of years ago....it might have been in one of his build threads though.... Can't remember which one.
            Hope you sort it out.
              • 18257
              Having never used VMS I can only give general comments. Matt varnish needs to have the living cramp shook out of it. Then stirred until you can no longer feel you hand. Good with the thinners (same brand) then more mixing IN A JAR. Never in the air brush. Test the mix on a card. If the mix is good, thin as milk but will not spray turn the air up. A little at a time untill it sprays.
              Build up a couple of light coats then finish with a more generous coating.
              • Komedy
                • Jan 2020
                • 307
                VMS Varnish is great but takes a little to get used to. This is what works for me very well. One or two drops of Acrylic Thinner added and then no more than 2 drops of flow improver, then run through a 0.4mm at 20PSI BUT with a light trigger action, don't pull full back, works a charm.
                • Jad
                  • Jan 2023
                  • 47
                  Would Vallejo thinner and flow improver work ?
                  • Komedy
                    • Jan 2020
                    • 307
                    Yes both are perfect but only a few drops of each, you are not doing what you would normally with other paint systems, i.e. get it milky thin. In truth its does work without either however I find a few drops of each just helps things along. The light trigger action is the key.
                    • Scratchbuilder
                      • Jul 2022
                      • 2689
                      Such a shame a good model has been spoiled this way. I use AK interactive Ultra Matte Varnish (AK 183) which dries really matte, it can be brushed or airbrushed.
                      • Panzerwrecker
                        • Mar 2022
                        • 575
                        • Los
                        • Wales, UK
                        I'm pretty sure it has dried before levelling out. I've never had an issue with their Satin or matt varnishes myself but it has always been applied through an airbrush. I pre mix with approx 10-20% of VMS thinner and spray at 20-25psi with a 0.4 needle.
                        • Richard48
                          • 1883
                          • Richard
                          • Clacton on Sea
                          Winsor and Newton Galleria Matt varnish is good for brush painting.I couldnt get a Matt finish on a 72nd Sherman after brush paintung Vallejo Gloss varnish followed by Matt.Peter Day told me about Galleria and it works well in thin layers.
                          Hooe that helps a bit.
                          Rich
                          • dave
                            • Nov 2012
                            • 1828
                            • Brussels
                            I will second Windsor and Newton Galleria, also comes in spray cans. If anything I find their Matt to be a bit too flat on occasion.
                            • stillp
                              • 8085
                              • Pete
                              • Rugby
                              Thirded.
