Varnish reacting with Revelle Aqueous paint
  • Bigfoot57
    • Jun 2015
    • 1101
    Just a quickie here I painted the model below using aqueous paints acrylics then to seal the final result sprayed it using Humbrol enamel varnish which was a mistake but also as Bob Ross the painter used to call a happy accident
    As you can see the paint has been attacked by in a subtle way to give the effect of worn and faded paint scheme which I could never achieve has anyone else had similar occurrence
    Regards
    Colin
ID:	1198835Click image for larger version
  • Mark1
    • Apr 2021
    • 4156
    Ive had this problem when i used to use revell, found there paints pretty good but this happened a few times when applying there matt varnish, think its a case of paint going on to wet and the matting agent floats to the surface.
      • 15633
      A happy accident for sure.
