Brush painting , burnt wood
  • Alan 45
    • Nov 2012
    • 9833
    How can I paint this to make it look like burnt wood?
    [ATTACH]73645.IPB[/ATTACH]
    • 18259
    Erm... Burn it. lol
    Do you have a heat gun for removing paint.... Might be a good idea to get it away from the plastic first though....Ask me how I know.
    • Alan 45
      • Nov 2012
      • 9833
      I was going to do that but I've stuck it pretty well to the walls and it's pretty flimsy plastic so it will break
      I can't use a lighter or match either because of the splinter affect I got when I broke the wood so painting is my only option I'm afraid
        Paint it with a patchy light and dark brown, then apply a heavy matt black wash, when this is still wet sprinkle bicarb on the areas you want to look charred. When this is all dry use a thin black wash to soak into the bicarb to give an ash effect.
        Have a look at my 'crash' SIG diorama to see the effect in situ.
        • Alan 45
          • Nov 2012
          • 9833
          Originally posted by \
          Paint it with a patchy light and dark brown, then apply a heavy matt black wash, when this is still wet sprinkle bicarb on the areas you want to look charred. When this is all dry use a thin black wash to soak into the bicarb to give an ash effect.Have a look at my 'crash' SIG diorama to see the effect in situ.
          Cheers Colin thanks for the info
